  • 8
Message 51 of 86
Re: Virgin HUB 3.0 - DHCP menu hangs
DHCP page still extremely slow to update as of 16th October 2019.
How can this still be an issue Virgin?
Yes we have all reset our routers etc blah de blah.
Please just accept there is an issue and fix it for god's sake.
  • 3.84K
  • 235
  • 482
Message 52 of 86
Hello Ju-Manc
Apologies that you have had to contact us.
According to our Systems your Hub has been online for for 9 days
Can you please try a reboot and see if that improves things
Gareth_L
  • 13.98K
  • 576
  • 1.33K
Message 53 of 86
My hub was at one point on for over a year and was fine but as it is its now been on for 125 days.
So really @Gareth_L you think 9 days is long and the OP has tried a reset and reboot you just will not fix this bug so you might as well not have this option so people will use modem mode and get their own router with 1Gb ports.
  • 15
  • 11
Message 54 of 86
Gareth, I'd suggest, with respect, that this response is disingenuous.
There is enough evidence in this forum alone (and surely in Virgin Media's own labs) to show that a reboot is irrelevant.
It's my understanding that a software kluge in an earlier update, intended to cure a potentially serious security flaw, now imposes a heavy burden on the processor that makes response times to activities like DHCP table editing run into several minutes.
It's true that a reboot might flush memory enough to shave a small percentage off that time, but the latency still leaves us with an unusable UI.
If I'm wrong about this I'd be very happy to be corrected.
Chris
  • 8
Message 55 of 86
Yes I have tried a reboot multiple times. It was like this when I first got the router and still is after multiple configuration change reboots.
You only have to read the disgruntled users with the same problem to maybe, with a little common sense, put two and two together to realise there is a software issue.
  • 56
Message 56 of 86
Another one here - it has just now loaded but it took ages. And my router has been rebooted recently. Guess if it gets there in the end not toooo seriou, but bloody irritating
  • 11
Message 57 of 86
 It seems the only fix is buy a new router and put the Virgin box in modem only mode 😞
  • 17
Message 58 of 86
Getting this issue a lot recently but only with devices on my 2.4ghz ssid. My boiler controller just doesn't obtain an ip address any more. Also the leases seem to be massively long well past the day that it says it should be.
I'll try resetting the router but doesn't seem like this fixes anything.
Come on Virgin...
  • 2.37K
  • 178
  • 250
Message 59 of 86
Sorry to hear of the issues that you've been having Pfb201.
Did your reset of the hub fix anything? Is there any sign of improvement since you did that or has it got worse?
Steven
  • 39
  • 11
Message 60 of 86
  • This issue has been going on for months. Have Virginmedia actually put any effort into fixing it? If not do you really think rebooting the Hub3 is going to help? This was one of many reasons I bought a separate router. Never had an issue since.
