  • 14.58K
  • 1.14K
  • 3.4K
Message 21 of 86
Re: Virgin HUB 3.0 - DHCP menu hangs
@Ellen_C
with respect - the complaint/question is that a page in the hub3 is slow to load - there is no other problem
the fault is known and well documented on here so how do you plan to help as you say you can
How's your connection at the moment? Are you still having issues? Please let us know so we can assist further.
____________________
Tony
  • 105
Message 22 of 86
Apologies for that.
We are aware of the issue and working hard to fix it.
Thank you for your patience. ^Ellen_C
Message 23 of 86
Any update on this? It's beyond annoying.
  • 13.96K
  • 574
  • 1.33K
Message 24 of 86
If you wait a long time it might get fixed but how long is too long for you? theirs still time to get your own router
BQM, Test for outgoing ports and SSL/L2TP VPN test
Message 25 of 86
I'm having the exact same problems.  I'm wanting to add about 20 devices to the DHCP reservation and it's painfully slow to add each device.  On the order of 5 minutes per device, and I'm doing it in stages to just keep my sanity.
This is on a newly installed HUB 3 after only about 2 days of being active with a wired connection to the hub.
If this is "normal" is there a guide to using the hub in modem mode and are there any recommendations on what 3rd party routers that people use?
If it is normal for this page to take minutes to load, then it's not really acceptable.  I've added DHCP address reservation to many other home routers, and this is without doubt the slowest by far.
  • 15
  • 11
Message 26 of 86
You're right—it's not in the least acceptable. You'll also discover problem 2: having painfully installed the DHCP allocation table there's absolutely no way to back it up. You can't back up the settings on this router at all!
VM has told us that it's working on a solution to problem 1. I don't believe they see problem 2 as an issue worthy of their endeavors. In fact, you used to be able to backup settings on an earlier version of the Superhub 2 until a firmware update swept away this industry standard feature.
Chris
  • 14.63K
  • 1.51K
  • 2.49K
Message 27 of 86
Yes VM have a page showing how to put the Hub in modem mode - just google it.  Re which 3d party router - that's a bit like asking "which car shall I get?".  Depends on what your requirements are and what budget you have.  I would say that very good entry level devices can be had for £50-80, whilst £150 would be around the "sweet spot" and £2-400 will get all singing and dancing features that gamers like.
Here are a few recent satisfied users...
https://community.virginmedia.com/t5/Networking-and-WiFi/replacing-router/td-p/3923472
https://community.virginmedia.com/t5/Networking-and-WiFi/Confused-new-router-needed-or-not/td-p/3798...
https://community.virginmedia.com/t5/Networking-and-WiFi/Superhub-3-Wifi-Issues-please-help/td-p/392...
Message 28 of 86
I did realise the question is very much like the "car" question - or even when I'm on the other end of the "what computer would you recommend for me" type questions.  I started going through old messages on the forum, but many thanks for the pointers to the articles.  I'm more the mid range user.  99% of the time, it'll be a few devices and no gaming reduced latency needed, and I'll be using it a for logging into work every so often. Having been on the "bad" end of a cheap router in the past that could not cope with loads of outbound NAT connections, I think I'll go for a mid range.  Again, thanks for the pointers.
  • 14.63K
  • 1.51K
  • 2.49K
Message 29 of 86
For your needs, you wont go far wrong with a mid priced Asus.
Message 30 of 86
Hello @Ellen_c ,
Is there an ETA to fix please? I'm having same problems. Even a short term workaround would be useful if there is one.
Xerxel
PS. Does anyone know if its possible to SSH into this router and use command line to configure DHCP?
