Message 1 of 7
Virgin Connect device names
I'm a new Virgin customer and my WIFI speed is poor.  I'm using Virgin Connect to identify If any of the connected devices are causing an issue.  5 of the devices are a range of letters and numbers (a bit like an IP number).  How can I tell what actual device these numbers refer to?
  • 2.66K
  • 55
  • 384
Problem sorter
Message 2 of 7
Re: Virgin Connect device names
...there should be somewhere within the app whereby you can rename the devices to whatever you like. Not sure exactly where but its probably the same screen where you can view connected devices. If you click on a device, the app should take you to the next screen where it shows info for that device + an option to rename it.
__________________________________________________________
Husband, Dad, Gamer, Gadget Lover......
Twitter: @deans6571
Message 3 of 7
Thanks deans6571, when I go into next screen the manufacturer is 'unknown' and the connection is Ethernet so as I haven't attached Ethernet cables I'm assuming they are Virgin boxes, but further than that ??  When I pause 1 of them in particular I do see amarked I provement in internet speed, I just don't know what actual device I'm pausing!
  • 2.66K
  • 55
  • 384
Problem sorter
Message 4 of 7
...there is definitely somewhere within the app whereby you can rename all the devices as in my app, I have all of my devices named i.e. TV, Bob's iPhone, Tom's tablet, Andy's phone, etc, etc.
Can't check right now as not at home to scan devices but it's definitely there somewhere (will have to check later tonight).
Twitter: @deans6571
  • 14.45K
  • 1.98K
  • 6.33K
Message 5 of 7
When you click on the connected device in the app the next window shows the MAC address of the device and the IP address that it is connected to.  The devices will usually have their MAC address printed on them somewhere, or it will be available from within the device settings, so with a bit of detective work you should be able to identify each device.  You can then rename them in the app as already suggested.
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
Message 6 of 7
Hi Graham_A, thank you for that.  I'll give that a try.
Message 7 of 7
Sorted!! As you stated Graham_A, the Virgin boxes MAC numbers tied in.  So now I know which box has the issue.  Many thanks for the responses Graham_A and dean s5671 - I appreciate the help..
