tecdude
  • 22
Virgin Connect Hub 4
I have a Hub 4, can I use the connect app?
Andrew-G
  • 6.96K
  • 1.22K
  • 3.04K
Re: Virgin Connect Hub 4
Not as far as I know.  VM are working on it, and it's only been a year and a half since the public launch of the Hub 4, so you'll need to cut them some slack.....
Steven_L
  • 5.28K
  • 371
  • 538
Hey @tecdude,
As @Andrew-G advised at the moment, you cannot use the connect app with the Hub 4 at the moment but I can assure you that the team are working on this.
Regards,
Steven_L
