Hoggie
  • 479
  • 6
  • 64
Fibre optic
Message 11 of 45
Re: Virgin 3.0 Hub Wifi keeps dropping all Wifi devices
My son had the same issue with the hub3 almost to the point of throwing it out the window.
Good old dad found the issue, co-axe had been damaged by building work being done by a neighbour.
So new better co-axel cable from splitter to the Hub3 router, and V6 box, cable routed out of the way in low traffic area.
my son now has a perfect connection with no wifi dropouts in over a month, V6 box is well happy and virgin didn't get the bill for repair.
Happy Days 🙂
Phil.
this post may contain nuts 😉
TrueVerdict
  • 26
  • 6
Message 12 of 45
i feel for you brother. The nasty reality of broadband is - ISP routers are absolute pants.... thats why companies have created Powerline adapters and mesh systems -(NOTE: do not ever buy a wifi repeater).
Once you acknowledge this reality your life will be come much simpler:
3 options are available:
1) buy your own (gaming) router and use that as the wifi hotspot - i say gaming because these generally have more power allocated to the wifi signal
2) buy a proper powerline adapter - devolo/tp link/netgear are the bigger brands - you may need more than the starter kit so 1 transmitter and 2 receivers.... - this is my most recommened option
3) Mesh systems - these are enhanced wifi which overide your routers nromal wifi functions.... still wifi though... still get interference- get a powerline...
If you find my responses help or amuse you in any way, please cheer me up and give me some Kudos - - - - Services: Hub3 500mb speedtest.net result 22 Jan 2021 = 550mb down / 36mb up Ping 12
urbanbumpkin
  • 50
  • 6
Dialled in
Message 13 of 45
I have got a couple of tp link power line adapters at the moment. One has WiFi at the far end of the kitchen and another is just Ethernet into a pc up stairs.
These don’t drop when the 3.0 hub WiFi drops.
any recommendations for gaming router?
So other options are to:-
buy another power line TP link WiFi box and run it where the router is.
Or buy an all singing mesh and start from scratch.
urbanbumpkin
  • 50
  • 6
Dialled in
Message 14 of 45
Happy Days 🙂
Phil.
Did the poor coaxial cable affect anything that was direct connected or jus WiFi?
gary_dexter
  • 31.34K
  • 1.94K
  • 4.22K
Message 15 of 45
Happy Days 🙂
Phil.
Who replaced the coax?
expatista
  • 37
Message 16 of 45
I have similar issues and am considering buying a third party router.  All of this stuff is greek to me but someone suggested I get a gigaport router.  Could I ask which 3rd party router you bought.  The VM connect app says that I should have a booster to get coverage in one of my rooms so I am looking for new router and booster system.
gary_dexter
  • 31.34K
  • 1.94K
  • 4.22K
Message 17 of 45
@expatista wrote:
If you get a router or mesh system you won't need a booster
expatista
  • 37
Message 18 of 45
Yea, I suppose I don't know what solution to go with.  Do I get a gigaport wifi router and then add some kind of mesh device to it if it doesn't help with distant room(s) or do I get a powerline and gigport hub? I think the issue is that I have a room far away from the VM Hub that is part of an new extension so there are (previously) external walls between my laptop and the home hub.
  • 26.51K
  • 2.7K
  • 4.92K
Message 19 of 45
See this I have posted before.
_________________________
I have never used wifi on a VM Hub ! Assuming your wired connections are all ok, then getting your own wireless equipment will solve any wifi issues permanently, and will be transferable to other BB suppliers kit should you move supplier.
Get either..... (1) A Mesh System, (2) A Wireless router, (3) A Wireless access point or (4) A combination of (2) & (3).
I would say a good Mesh will be the best/simplest/most flexible for most average users.  A Triband system is better for the "backhaul" and for users on high speed packages and umpteen simultaneous connections.
It depends on your requirements for... better routing features, your house layout, size, construction materials, your tech abilities, and of course, budget, ~£60-80 will get a decent introductory wireless router but 'may' not alone solve the wifi in your house, but spending up to ~£500 will get the “Rolls Royce” solution of a high-end Wifi6 Router & WAP's or a top end Tri-band Mesh system. You'll probably want something suitable - somewhere within that range - I reckon ~£100-150 is around the “sweet spot” for most standard users, and where you would probably need to start for a standard 2/3-story house if it has brick walls. Less for a one-bedroom modern build flat, more for a mansion
expatista
  • 37
Message 20 of 45
Thanks!  Yes the 2 storey house with external brick walls is my situation.  Thinking high end wifi router with access point.
