  • 8
Message 1 of 14
Very slow upload speed
I have a Hub 3.0 and the upload speed has been very bad over the past few days. Im on the M200 package. My PC is wired directly to the hub. Am getting around 180Mbps download and 0.1Mbps upload. This makes the internet access unusable even with basic browsing let alone working from home. Calling the support line the automated message notes there is an issue and will be fixed but the website page that notes no issues for internet access for my area. The Hub has been rebooted numerous times but upload speed does not improve much. Maybe up to 0.3Mbps. No loose cabling inside or outside the house. I have set BQM monitoring off.
I have tried to attach all the router stats from the Hub but all the characters exceed message post limit. Which is required for troubleshooting ?
Thanks.
  • 3.65K
  • 283
  • 513
Superfast
Message 2 of 14
Re: Very slow upload speed
@paulm_2020 wrote:
Thanks.
Split the data into multiple posts, and click post twice if you get a generic 'HTML' error.
  • 8
Message 3 of 14
OK. Here are the router status :
298750000
Locked
Ranged Upstream Channel (Hz)
60300000
Locked
Provisioning State
Online
12987500004.638256 qam21
21387500004.338256 qam1
31467500004.938256 qam2
41547500004.938256 qam3
51627500004.838256 qam4
61707500004.838256 qam5
71787500004.938256 qam6
8186750000538256 qam7
91947500004.938256 qam8
102027500004.638256 qam9
112107500004.638256 qam10
122187500004.638256 qam11
132267500004.538256 qam12
142347500004.538256 qam13
152427500004.338256 qam14
162507500004.140256 qam15
172587500004.338256 qam16
182667500004.438256 qam17
192747500004.138256 qam18
20282750000438256 qam19
212907500004.538256 qam20
223067500004.138256 qam22
233147500004.138256 qam23
243227500004.438256 qam24
1Locked38.93880
2Locked38.950
3Locked38.630
4Locked38.630
5Locked38.970
6Locked38.6240
7Locked38.91400
8Locked38.97280
9Locked38.6187780
10Locked38.6499860
11Locked38.931970
12Locked38.9130710
13Locked38.93246350
14Locked38.95633250
15Locked38.96165590
16Locked40.36413730
17Locked38.64674120
18Locked38.93561000
19Locked38.9837560
20Locked38.952840
21Locked38.911010
22Locked38.95540
23Locked38.69180
24Locked38.9303640
16030000040.5512064 qam1
23940000040.5512064 qam4
34620000040.5512064 qam3
45370000040.5512064 qam2
3ATDMA0000
4ATDMA0000
  • 8
Message 4 of 14
Part 2 :
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
4k;fg87dsfd;kfoA,.iyewrkl
SFID8533
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID8532
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
16/11/2020 09:26:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 18:39:46noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 18:39:46ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 06:48:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 16:47:6noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 16:47:6ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 04:47:6noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 04:47:6ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 19:50:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 04:17:51noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 04:17:51ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 21:52:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 16:16:30noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 16:16:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 15:10:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 04:16:30noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 04:16:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/10/2020 02:37:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 16:16:30noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 16:16:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 24.77K
  • 1.43K
  • 3.15K
Message 5 of 14
Levels are fine.. we need to see the BQM
  • 3.65K
  • 283
  • 513
Superfast
Message 6 of 14
As Gary states the stats look ok although there are a large number 'Pre RS Errors' that your HUB has to correct, which can slow things down.
1Locked38.93880
2Locked38.950
3Locked38.630
4Locked38.630
5Locked38.970
6Locked38.6240
7Locked38.91400
8Locked38.97280
9Locked38.6187780
10Locked38.6499860
11Locked38.931970
12Locked38.9130710
13Locked38.93246350
14Locked38.95633250
15Locked38.96165590
16Locked40.36413730
17Locked38.64674120
18Locked38.93561000
19Locked38.9837560
20Locked38.952840
21Locked38.911010
22Locked38.95540
23Locked38.69180
24Locked38.9303640
When was the last time your HUB was rebooted?
  • 8
Message 7 of 14
Thanks for the quick replies. The Hub was rebooted around 10.40am this morning. Also I should have said I have set BQM monitoring on for the past few hours. Will leave it running
  • 24.77K
  • 1.43K
  • 3.15K
Message 8 of 14
Post the live share URL to the BQM please
  • 8
Message 9 of 14
  • 3.65K
  • 283
  • 513
Superfast
Message 10 of 14
@paulm_2020 wrote:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/8da9c618cc1a28bae54a32570225386cdc...
Terrible BQM. You certainly have an issue with your line, or an issue in your area.
