Anonymous
Not applicable
Message 1 of 7
Very slow download speed and consistent, large spikes in ping
6 people total are using this router. When doing speed tests we seem to get around 10-40Mbps download speed. Large spikes in ping also making voice calls/video calls impossible to do.
Stats from hub:
Network:
15/11/2020 14:38:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 14:13:12noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 14:13:12ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 19:25:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 02:13:12noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 02:13:12ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 19:21:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 14:45:42noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 14:45:42ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 14:15:41noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 14:15:41ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 03:47:11noticeSW download Successful - Via NMS
03/11/2020 03:45:7noticeSW Download INIT - Via NMS
03/11/2020 01:08:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 00:40:50noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 00:40:50ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 14:38:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 12:40:50noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 12:40:50ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Downstream:
16990000000.540256 qam37
25390000002.940256 qam17
35470000002.440256 qam18
45550000002.540256 qam19
55630000002.740256 qam20
65710000002.240256 qam21
75790000002.240256 qam22
85870000002.540256 qam23
95950000001.540256 qam24
106030000001.740256 qam25
11611000000240256 qam26
126190000001.540256 qam27
136270000001.440256 qam28
146350000001.740256 qam29
15643000000140256 qam30
16651000000140256 qam31
176590000001.540256 qam32
186670000000.740256 qam33
196750000000.940256 qam34
206830000001.240256 qam35
216910000000.740256 qam36
227070000001.240256 qam38
237150000000.540256 qam39
247230000000.240256 qam40
Upstream:
16030003143512064 qam1
23939999143512064 qam4
34619999143512064 qam3
45370000043512064 qam2
Tags (2)
  • 24.72K
  • 1.43K
  • 3.14K
Message 2 of 7
Re: Very slow download speed and consistent, large spikes in ping
What are your wired speeds like?
Anonymous
Not applicable
Message 3 of 7
I don't believe anyone has an ethernet cable to test this with unfortunately.
  • 24.72K
  • 1.43K
  • 3.14K
Message 4 of 7
Virgin do not guarantee wireless speeds or connectivity.
Unless you can run a wired test then there’s not much more can be done.
Anonymous
Not applicable
Message 5 of 7
I'll have a look around for an ethernet cable in that case.
Anonymous
Not applicable
Message 6 of 7
Alright it turns out we do have an ethernet cable. Speed test resulted in 13.52Mbps download and 20.55Mbps upload.
  • 24.72K
  • 1.43K
  • 3.14K
Message 7 of 7
From what device?
