Reidos
  • 5
Message 1 of 10
Very low upstream speed Hub 5,wired and wireless
Guys, first post be gentle.
The last few days I'm getting very low to occasionally zero upstream speeds both on wired and wireless.
Hub is in modem mode and i have had my existing set up for a number of months.
Below is lifted from the Hub, tried various power downs, cable security etc to no avail.
Earlier it cut of completely, any assistance appreciated.
Cheers
06030000036.35120QPSK5
15370000036.35120QPSK6
24620000036.55120QPSK7
33940000036.85120QPSK8
0ATDMA00170
1ATDMA00240
2ATDMA00160
3ATDMA00140
14-03-2023 18:49:24criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:49:01noticeREGISTRATION COMPLETE - Waiting for Operational status
14-03-2023 18:48:54noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:48:51noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:48:48warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:48:46noticeHonoring MDD; IP provisioning mode = IPv4
14-03-2023 18:48:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:48:24criticalDHCP FAILED - Request sent, No response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:48:20criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:46:22criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:46:19noticeHonoring MDD; IP provisioning mode = IPv4
14-03-2023 18:46:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:46:02criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:32:05criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:31:22criticalTFTP failed - configuration file NOT FOUND;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:31:17warningToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:31:16warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:31:01criticalDHCP FAILED - Request sent, No response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:30:52noticeHonoring MDD; IP provisioning mode = IPv4
14-03-2023 18:30:50criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:30:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:30:41criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:29:57criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:29:36criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:28:40criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:27:32criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:27:28noticeHonoring MDD; IP provisioning mode = IPv4
14-03-2023 18:27:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:27:09criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:27:08warningLost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:26:56criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 18:26:54criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • 20.45K
  • 828
  • 2.2K
Message 2 of 10
Re: Very low upstream speed Hub 5,wired and wireless
You have bad upstream you need someone round to fix it.
jem101
  • 4.82K
  • 483
  • 2.13K
Superstar
Message 3 of 10
Oh now come on, we’re always gentle, well most of us anyway!
You have a cable fault, look at the very first table you posted, the modulation being all QPSK is a sign of the hub not being able to communicate properly with the CMTS (that’s the big device at the far end of the cable) due to excessive interference or noise being introduced. And the most likely source of noise is a bad cable joint.
Probably this will require a tech visit to find the issue, but in the meantime, what you can do is to start at the hub and systematically trace the cables back from it all the way to the ‘omnibox’ on the outside front wall and just check that all the connections are good, not become loose and no obvious signs of damage to the cable. The connections really only need to be ‘finger tight’, it’s sometimes best to disconnect and then reconnect them!
Failing that and finding something obviously wrong then, alas, you’ll need to brave the VM customer service provision and try to get them to agree to send someone out and not just opt for the much cheaper, ‘turn it off and on again and wait 15 minutes’!
Reidos
  • 5
Message 4 of 10
Thanks for the tip, I'll remove/reconnect all the connections and then check the hub to compare both tables .
Reidos
  • 5
Message 5 of 10
Updated table after disconnecting then reconnecting all relevant cables
060300000365120QPSK5
153700000365120QPSK6
24620000036.35120QPSK7
33940000036.55120QPSK8
0ATDMA0000
1ATDMA0070
3ATDMA000
0
TimePriorityDescription15-03-2023 18:20:13noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 18:15:51noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 18:11:12noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 18:10:31criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 18:08:53noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:56:47noticeREGISTRATION COMPLETE - Waiting for Operational status15-03-2023 17:56:40noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:56:39noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:56:36criticalDHCP FAILED - Request sent, No response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:56:36warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:56:27noticeHonoring MDD; IP provisioning mode = IPv415-03-2023 17:56:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:43:51criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:43:46criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:42:56criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:42:55criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:42:50criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:42:49criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:42:19criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:42:18criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:39:57criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:39:56warningMDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;15-03-2023 17:39:53criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;14-03-2023 18:49:24criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;14-03-2023 18:49:01noticeREGISTRATION COMPLETE - Waiting for Operational status14-03-2023 18:48:54noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;14-03-2023 18:48:51noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;14-03-2023 18:48:48warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;14-03-2023 18:48:46noticeHonoring MDD; IP provisioning mode = IPv414-03-2023 18:48:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;14-03-2023 18:48:24criticalDHCP FAILED - Request sent, No response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;14-03-2023 18:48:20criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1
Reidos
  • 5
Message 6 of 10
There certainly is upstream speed improvement doing a speed test, unsure if the tables reflect that but it still isn't how I reckon it should be.
  • 1.82K
  • 112
  • 415
Super solver
Message 7 of 10
Check for a known local fault : 0800 561 0061 - seeing QPSK modulation is quite unusual.
Reidos
  • 5
Message 8 of 10
The response on the call suggested an issue but 'as it is very complicated it is taking longer than usual'.
Strange as when i check the postcode online it says the broadband is fine.
My parents live in the same street and are virgin subscribers so I'll pop round there and check theirs.
  • 1.82K
  • 112
  • 415
Super solver
Message 9 of 10
The 0800 561 0061 number is by far the most local focused and up to date.
Half of Colchester has to have blank TV screens and / or an Internet outage before "Check service status" link starts to report issues.
Martin_N
  • 8.87K
  • 371
  • 536
Message 10 of 10
Hi Reidos,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue with your broadband service.
I have taken a look on our side and can see there is a reported intermittent issue in your area.
The reference for this is: F010545920.
The estimated fix date is: 23 MAR 2023 09:55.
^Martin
