  • 14
Very intermittent Wifi speed and connection.
Please help
I have been with Virgin for over 2 month and have had no success if getting my WiFi fixed despite a number of calls to the help desk.
So here are all the issues I am having
  • Vbox would hangup when streaming from Netflix,Iplayer etc even though it is only 1 meter from my HUB.
  • Streaming between Vboxs usually doesn't work.
  • Connecting more than 1 device to the 2.4Ghz band is almost impossible.
  • Wifi download speeds will drop down to <5Mbps for no reason, I have to disconnect and reconnect to restore the speed.
I have a 500Mbps contract and expect to be able to use this reliably for work but I am having so much problems that it has become a major issue when using it for VOIP calls or accessing work servers via  a VPN. Family members have become so frustrated with it that they are using the mobile network in preference the WiFi.
I hope that someone from technical support can respond to this and provide better support than I have already received from the call centres.
  • 20.96K
  • 1.13K
  • 2.7K
Re: Very intermittent Wifi speed and connection.
What speed do wired devices achieve?
  • 14
Wired device will get the full 500Mbps download, wireless devices will regularly get 150Mbps. When its working its great, its just not working often enough.
  • 20.96K
  • 1.13K
  • 2.7K
If you’re getting the full speed wired then there’s no issues with the connection to the hub
  • 14
Agreed. The issue seems to be with the low quality router.
  • 20.96K
  • 1.13K
  • 2.7K
Then you need to put the hub in modem mode and get your own router or mesh system to improve your wifi requirements
