Message 1 of 7
Very Slow wifi
We have, since starting our M200 package, experienced nothing but slow wifi that keeps cutting out and that is, quite frankly, not good enough - to the point that we are considering leaving this service. We have moved the wifi box around the flat, and had 2 people come in and tell us a 'box outside/under the road' needs to be fixed... but nothing has been done since the first guy came in a month ago! Can someone help before we decide to move to a different provider?
  • 24.32K
  • 1.39K
  • 3.09K
Message 2 of 7
Re: Very Slow wifi
What are wired speeds like?
You don’t pay for WiFi speeds and they are not part of your contract or speed guarantee.
Message 3 of 7
Re: Very Slow wifi
It's more the fact they keep cutting out, and we repeated get download speeds around 90mbps when we pay for around 200
  • 24.32K
  • 1.39K
  • 3.09K
Message 4 of 7
Re: Very Slow wifi
Wired speeds?
Message 5 of 7
Re: Very Slow wifi
We only really used wired and it still cuts out
  • 11.38K
  • 888
  • 1.45K
Message 6 of 7
Re: Very Slow wifi
So it isn't Wi-Fi at all, it is an ethernet connection.
Then
Can you please
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 24.32K
  • 1.39K
  • 3.09K
Message 7 of 7
Re: Very Slow wifi
But your opening post says WiFi speeds?
