byron_hinson
  • 165
Very Iffy Connection
For the past few days we have had an up and down performance from our 500mb broadband. Its usually fine: Can someone check out our modem settings etc see if it seems ok:
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
203000000
1.4
40
256 qam
9
2
211000000
1.2
40
256 qam
10
3
219000000
0.9
40
256 qam
11
4
227000000
0.7
40
256 qam
12
5
235000000
0
40
256 qam
13
6
243000000
0
40
256 qam
14
7
251000000
-0.4
40
256 qam
15
8
259000000
-0.5
40
256 qam
16
9
267000000
-0.4
40
256 qam
17
10
275000000
-0.5
40
256 qam
18
11
283000000
-0.7
40
256 qam
19
12
291000000
-0.2
40
256 qam
20
13
299000000
-0.2
40
256 qam
21
14
307000000
0
40
256 qam
22
15
315000000
0.4
40
256 qam
23
16
323000000
0
40
256 qam
24
17
331000000
0
40
256 qam
25
18
371000000
-0.2
40
256 qam
26
19
379000000
-1
38
256 qam
27
20
387000000
-1.2
40
256 qam
28
21
395000000
-1.2
38
256 qam
29
22
403000000
-1.9
38
256 qam
30
23
411000000
-1.9
40
256 qam
31
24
419000000
-2.5
38
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
1225
180
2
Locked
40.3
333
10
3
Locked
40.9
103
0
4
Locked
40.3
94
0
5
Locked
40.3
106
0
6
Locked
40.3
121
0
7
Locked
40.3
204
0
8
Locked
40.9
287
0
9
Locked
40.3
287
0
10
Locked
40.9
192
0
11
Locked
40.9
164
0
12
Locked
40.3
194
0
13
Locked
40.3
237
0
14
Locked
40.3
184
0
15
Locked
40.9
205
0
16
Locked
40.3
274
0
17
Locked
40.3
250
0
18
Locked
40.3
327
14
19
Locked
38.9
385
0
20
Locked
40.3
464
0
21
Locked
38.9
493
0
22
Locked
38.9
539
0
23
Locked
40.3
577
0
24
Locked
38.9
923
0
Tags (1)
byron_hinson
  • 165
Re: Very Iffy Connection
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
25800035
43.8
5120
64 qam
6
2
46200258
45
5120
64 qam
3
3
39400000
44.5
5120
64 qam
4
4
32600000
44.3
5120
64 qam
5
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
5
0
3
ATDMA
0
0
5
0
4
ATDMA
0
0
0
0
 General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053-b.cm
SFID
461120
Max Traffic Rate
575000000
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
461119
Max Traffic Rate
38520000
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
byron_hinson
  • 165
Corey_C
  • 3.45K
  • 186
  • 271
Thanks for your post and reaching out to the Community Forums, byron_hinson,
Sorry to hear that you have been having connections issues with your broadband. I've run some remote diagnostics on your connections, and it does indicate that you are currently being affected by a local area fault ref#C01198514 and we are working to get this sorted as quickly as possible. The current ETA fix time is 29 APR 2021 18:00. Apologies again for the inconvenience.
Cheers,
Corey C
