  • 5
Message 1 of 9
VPN issue at home
I am having issues working from home and accessing my work AlwaysOnVPN.
I've contacted my work IT and they say they have done everything they can. I can access the VPN when using my mobile as a personal hotspot. So it does seem it is something with Virgin but my husband is using his work VPN using same wifi connection with no issues.
It does try to connect and then it fails with the error
'The network connection between your computer and the VPN server could not be established because the remote server is not responding. This could be because one of the network devices (firewalls, routers etc) between your computer and the remote server is not configured to allow VPN connections.
Many thanks
  • 20.96K
  • 1.13K
  • 2.7K
Message 2 of 9
Re: VPN issue at home
Disable the firewall on the virgin hub
  • 5
Message 3 of 9
Thanks, I've tried that and it's still not working
  • 1.72K
  • 56
  • 218
Super solver
Message 4 of 9
As your other half's is working, proves VPN and VM are ok.
When you  logon to the "Always on VPN" app on your laptop, does that show an error at all.
Red (VM SH2 AC Beta tester)
Running on 500Mb VM service with SH3 in Modem Mode, with a ASUS RT-AC5300 router. With this setup I get Fantastic WIRED and WIRELESS Signals in my home. I dont work for VM. But I work in IT, and I know my tech.
My advice is at your own risk. If you are happy with my answers please press Kudo ?
  • 88
  • 5
Up to speed
Message 5 of 9
I know less than nothing about VPN's, however.........
Port forwarding
This function allows for incoming requests on specific port numbers to reach web servers, FTP servers, mail servers etc
is where I might look to enable/extend the Port Number range just in case you are out of range?
and I have read here...
to try and establish he port number for the appropriate software.
All is Calm
  • 5
Message 6 of 9
This is the error I receive.
Many thanks!
  • 5
Message 7 of 9
  • 14.29K
  • 592
  • 1.37K
Message 8 of 9
Their are many VPN types
Try with the hub in modem mode.
  • 5
Message 9 of 9
Sorry image isn't uploading.
It says ;The network connection between your computer and the VPN server could not be established because the remote server is not responding. This could be because one of the network devices (firewalls routers etc) between your computer and the remote server is not configured to allow VPN connections.
