Message 1 of 9
VPN Hub3 again
I've been using a VPN with no issues for the last 12 months . Now I can't connect to my office server for the last 7 days any ideas what VM have done? Or what I can do? Have used an ethernet cable into the hub with no joy.
Tech support was useless
  • 14.24K
  • 590
  • 1.37K
Message 2 of 9
Re: VPN Hub3 again
See if it works with the hub in modem mode.
Message 3 of 9
Re: VPN Hub3 again
I want VM to fix the problem.
I had no VPN issues until last Tuesday.
I understand it is a common issue with this Hub- I don't understand given that somany people are working from home, that VM don't have a solution other than make you hub a modem and the get another router?
  • 8.36K
  • 83
  • 564
Superstar
Message 4 of 9
Re: VPN Hub3 again
If you're using the Hub 1 then it might have gone past its sell-by date, login to your Hub in router mode http://192.168.0.1/  and copy and paste your upload and download files and config file, there might be something there that explains what's gone wrong.
Message 5 of 9
Re: VPN Hub3 again
Sorry for my lack of information I am using Hub 3.0
  • 20.96K
  • 1.13K
  • 2.7K
Message 6 of 9
Re: VPN Hub3 again
Please try with the hub in modem mode as already suggested
Message 7 of 9
Re: VPN Hub3 again
Hi Gary I am also having VNP Hub3 issues.
Forgive my question, but how can I use the Hub3 in "modem mode"? I believe I need to change the settings?
Lorena
Tags (1)
  • 20.96K
  • 1.13K
  • 2.7K
Message 8 of 9
Re: VPN Hub3 again
What issues?
  • 14.24K
  • 590
  • 1.37K
Message 9 of 9
Re: VPN Hub3 again
https://www.virginmedia.com/help/virgin-media-hub-modem-mode
