  • 13
Message 61 of 71
Re: VM WiFi booster disappointment - not working
I have tried to post the pics but it’s just showing two causation signs and not the image on the post
  • 2.6K
  • 141
  • 240
Message 62 of 71
Thanks. Can you connect the Booster without the WiFi  symbol to your router following the instructions please.
And the one with the WiFi symbol in the room/area where you would like the signal to be stronger.
To be clear, the WiFi symbol is the 3 lines and "dot" , it is shown on the 2nd picture you posted.
Regards,
Lisa
  • 13
Message 63 of 71
I am an electrical engineer to trade. This is how it is done at the moment it puts my WiFi down to 50mps and drops out connection to devices etc.
not very good at all
  • 2.6K
  • 141
  • 240
Message 64 of 71
I'll send you a Private Message so I can take a look at your account and network details.
Please reply back to it so I can help.
Lisa
  • 174
  • 25
  • 44
Superfast
Message 65 of 71
Try logging into the booster via its IP address and going into the wifi configuration settings. You can find the IP address by logging into your router and going to the connected devices screen.
Set the booster to 20/40/80Mhz if it isn't already on that.
A couple of other points:
If the booster is in a place where the signal from the router isn't particularly weak - you might get issues like this. Make sure the booster is somewhere with an actual black spot.
As a test, you could use the wifi one right next to your computer upstairs and use an ethernet cable. If the speed is still very slow, the bottle neck could be caused by the mains wiring.
  • 13
Message 66 of 71
Ok tonight I have turned off the 2.4ghz setting. I have a much better signal on my mobile now so I will give that a try and see how I get on.
Done a speed test on my phone in the bedroom getting 90mpbs
done it in my computer room (connected straight to router) getting 150mbps I am happy with that as long a song my pc stays on the router I don’t care. Is there a way I can tell the PC NOT to go onto the booster I think the router is closer than the booster anyway but just want to make sure.
surely those speeds are ok?
Message 67 of 71
The wifi boosters are not great.  I hard wired mine to simply turn them into a wireless repeater.  Basically i connect a network cable from the hub to the port on the wireless powerline,  no need to use the other adapter.  So its getting full speed to the wireless adapter and then can in theory pump that out.  I have a tp link 1200 wireless powerline that i get the full 500mb wirelessly on my 500mb connection but the virgin netgear ones i get 300 to 400mb and often much less.  I am in a 3 bed small house and i have to put wireless powerlines run this way in all rooms as the superhub 3's wireless coverage is so bad.
Message 68 of 71
Hi all, what a great resource this is. Okay, so as many of you on here have said I too received a pair of WiFi boosters for the back of my house. I have a 500mbps connection and in the back bedroom I’m getting around 10mbps. It’s not a particularly large house, just a three bed semi and in that back bedroom we are using a tplink network plug so that my son can at least play his PlayStation via Ethernet. So having installed the booster today I was really disappointed by the speeds, less than 5mbps! I kept the boosters original name so I could be sure that I was testing the right connection. I will try a different plug socket as mentioned on this forum, but it was sold to me as giving us the same or very close to the connection speed we have right next to the router. Did anyone on here actually get this sorted using the boosters to a decent speed in the end???
Tags (1)
  • 20.96K
  • 1.13K
  • 2.69K
Message 69 of 71
You’ll struggle to get decent speeds on a powerline extender.
Booster is the wrong word to use.
Message 70 of 71
Thanks for the reply, it’s a shame as I was really hoping to improve the signal. I think I’ll switch the virgin router to modem mode and get a powerful router 😞
