on 14-02-2023 16:13
I hope this is a quick & easy question to answer.
How do I find and export the network activity/diagnostic logs from VM Hub 3? If I log into the admin interface, is it immediately obvious or is it hidden such that I need a secret knock and handshake to expose them? Many thanks
on 14-02-2023 16:29
on 14-02-2023 18:21
How to get stats from a VM hub (no need to logon to the hub)
Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
on 15-02-2023 07:06
@Tudor wrote:How to get stats from a VM hub (no need to logon to the hub)
- Click on the “> Check router status” button
- Click on the “Downstream” tab, copy the text and paste into your reply, do not take a screen shot
- Click on the “Upstream” tab, copy the text and paste into your reply
- Click on the “Networking” tab, copy the text and paste into your reply.
- Do NOT post photos or screen shots they will be rejected as they contain MAC addresses. The board software will automatically change MAC addresses to **:** if done as above.
Thanks Tudor. So, I can see the network log, but it only presents a short section of log from around the time of the hub installation. Is there a config setting to refresh the network log? Basically, I want to capture the network log around the time that I'm seeing broadband dropouts, so I need to see current log data. Any ideas?
