  • 5
VM Hub 3.0 is working but there are no green indicator lights on the front
VM Hub 3.0 is working, but there are no green lights on the front.
I'm happy that its working, but it seems strange that there are no indicator lights (the white power light is on).
Does anyone have an explanation - and is it an actual issue (its a nuisance, but is it sign of something more serious?)
Tags (1)
  • 2.21K
  • 163
  • 290
Dialled in
Re: VM Hub 3.0 is working but there are no green indicator lights on the front
The white light is all you expect when everything is good!
All other lights generally show when something isn't working correctly, or the HUB has recently rebooted.
  • 5
Thanks for the reply - that's all good then!
