  • 1.12K
  • 14
  • 72
Rising star
Message 21 of 33
Re: VM Hub 3.0 Flashing Green WiFi light
Same issue for me, called 150 'Mohammed' from where ever ran tests to no avail. I rebooted also to no avail.  He said it was because the system was updating.  Phoohy!!.  Advice not fit for purpose.  Followed advice from on here held WPS button down for 30 secs and it went out.  Wonder why it started however?
Maybe VM should advise service advisors or they should look on here.
Finally I would add there were no issues with the supply.
Message 22 of 33
Sorry, I'm a complete duffus. I have the solid white base light and flashing green WiFi light. If I press reset to see if that clears it, does it affect devices, password etc?
  • 4.18K
  • 167
  • 231
Message 23 of 33
Hi FFumbler,
Thank you for your post and welcome to the community.
It sounds like you are rebooting the hub. This will power off the hub and then power it back on. It will not change the password or the settings on the hub.
^Martin
Message 24 of 33
Thank you - so I do need to press the reset button?  Sorry Martin, am an absolute dullard.
  • 4.18K
  • 167
  • 231
Message 25 of 33
Are you having issues accessing your broadband service?
^Martin
Message 26 of 33
No, no problem at all but the green wifi light is constantly flashing even after the old "turn it on and off" routine and I've no idea why.  The white base light is constant and no other lights are showing.
  • 4.18K
  • 167
  • 231
Message 27 of 33
Can you press the WPS button on the Hub 3?
^Martin
Message 28 of 33
I have reset the HUB 3 to the factory set-up by pressing the reset button for 20 seconds. This did not resolve the issue but forced me to set all devices connected to the HUB using the WPS method, when all devices been connected. I reset the HUB and to my surprise green light is not flashing anymore. The only thing I can think about it is that the Printer (more likely) or one of the devices was to trying to pair with HUB continuously. I think the problem occurred, when I changed the Hub's PW (the green light start flashing).
Note: I did not use WPS to set the new PW to all devices, I typed in the PW.
Hope that help.
Good luck
  • 57
  • 7
Message 29 of 33
I have had the flashing green light for around a week now. Anyway to fix this? Cheers.
  • 9
  • 5
Message 30 of 33
On the basis of 'How often do I use it anyway?' I have turned off the WPS function and that has removed the flashing light. Not the answer I was hoping for and Virgin really should put more effort into solving the problem but at least the annoying flashing light has now gone.
Details of how to access the hub settings page are on a sticker on the bottom of the your Hub3
This has proved to be a permanent fix for many months, all other resets etc were only temporary fixes (at least in my case)
