  • 9
  • 5
Message 11 of 33
Re: VM Hub 3.0 Flashing Green WiFi light
Unfortunately this has been going on for a couple of weeks, yesterday I did the 'hold the WPS button' trick and the flashing wifi symbol stopped, today it's started again!
Can't understand why Virgin have nothing to say when the problem has been known about for so long?
Message 12 of 33
I have this problem. I have a terrible time with Virgin who say there is nothing wrong!!!!!. When they do an auto system check on phone the Hub reboots so there must be a problem. They sent an engineer who replaced the Hub telling me it was a fault with the hub. The new hub is still flashing !!!, still virgin say there is nothing wrong.
Comes to something when they don't know there own product.
  • 9
  • 5
Message 13 of 33
On the basis of 'How often do I use it anyway?' I have turned off the WPS function and that has removed the flashing light. Not the answer I was hoping for and Virgin really should put more effort into solving the problem but at least the annoying flashing light has now gone.
Details of how to access the settings page are on a sticker on the bottom of the your Hub3
  • 16
Message 14 of 33
My Hub 3 just started doing this today.  It doesn't seem to be causing any problems but it's always worrying when something occurs out-of-the-blue like this. I don't know what a WPS button is but I'll have a look later when I get back home and see if it fixes things.
Message 15 of 33
Same issue! Started flashing two days ago! Just tried WPS button and about 2 mins later it stopped! Will see if it stays off
  • 7
Message 16 of 33
Mine started flashing the day I got Sky Q with extra room boxes. He told me that the boxes communicate through WiFi to the main box, which is why it constantly flashes.
Not it sure if this helps you or anybody, just saying what I was told.
  • 52
  • 18
Dialled in
Message 17 of 33
My Hub 3.0 started doing this a few days ago. I've tried turning off and on again but it continues. I've also tried the WPS button fix but although it goes off it comes back on again after a short while. Router diagnostics show a red triangle next to WiFi but it all seems to be working fine. Hub status overview shows Internet online but next to Wireless it says "On (2.4 and 5 GHz), WPS in progress)".
So again it looks as if it has something to do with the WPS but why has it suddenly started to do this. All Ethernet and WiFi connections are working as normal. Router info shows:
Hardware version: 10
Software version: 9.1.116.608
Is that the latest firmware version? Driving me nuts!
  • 9
  • 5
Message 18 of 33
This thread has been going since last June, Virgin obviously has no interest or answers.
The only thing that stopped the problem from recurring every couple of days was to turn off the WPS function.
  • 2.06K
  • 127
  • 401
Problem sorter
Message 19 of 33
WPS should never be left on.  It's only there as a quick and convenient way to pair up WiFi devices, and this can be done anyway without WPS.
My advice would be to turn WPS off unless you can't do without it. It's also a known security risk.
Just joined
Message 20 of 33
I have the same issue, I do the usual power cycle and it seems to go away for a week or two, but at least it’s comforting to know that this is a bug that doesn’t affect the operation of the Hub3
