Darkmoon
  • 37
Message 1 of 34
VM HUB3 Rebooting
I have noticed over the last week or so my Hub 3 rebooting 2-3 times a day.  not sure whats going on
I did notice the hub running warm, but seems to be well ventilated.
My network log and stats posted below.
07/09/2020 20:45:0	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
07/09/2020 17:30:41	notice	LAN login Success;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
07/09/2020 17:30:34	Warning!	LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
04/09/2020 19:54:22	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
04/09/2020 16:26:44	notice	LAN login Success;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
04/09/2020 01:11:35	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 13:59:48	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 02:24:11	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 00:32:41	notice	DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u+voc-b.cm modified;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 00:32:41	Error	DHCP REBIND WARNING - Field invalid in response;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 23:41:19	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 23:17:58	notice	LAN login Success;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
29/08/2020 21:10:43	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 08:27:46	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 16:50:27	notice	DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u+voc-b.cm modified;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 16:50:27	Error	DHCP REBIND WARNING - Field invalid in response;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 11:09:31	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 06:49:53	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 05:28:38	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
Regards...
Darkmoon
  • 37
Message 2 of 34
Re: VM HUB3
Channel	Frequency (Hz)	Power (dBmV)	SNR (dB)	Modulation	Channel ID
1	291000000	-1.9	36	256 qam	20
2	139000000	-1.4	36	256 qam	1
3	147000000	-1.4	37	256 qam	2
4	155000000	-1	37	256 qam	3
5	163000000	-1.2	37	256 qam	4
6	171000000	-1	36	256 qam	5
7	179000000	-1	37	256 qam	6
8	187000000	-1	37	256 qam	7
9	195000000	-0.9	37	256 qam	8
10	203000000	-0.9	37	256 qam	9
11	211000000	-1.2	37	256 qam	10
12	219000000	-1	37	256 qam	11
13	227000000	-1.2	37	256 qam	12
14	235000000	-1.5	37	256 qam	13
15	243000000	-1.7	37	256 qam	14
16	251000000	-1.7	37	256 qam	15
17	259000000	-1.7	36	256 qam	16
18	267000000	-1.9	37	256 qam	17
19	275000000	-1.9	37	256 qam	18
20	283000000	-1.7	37	256 qam	19
21	299000000	-1.9	36	256 qam	21
22	307000000	-1.7	37	256 qam	22
23	315000000	-1.7	37	256 qam	23
24	323000000	-1.7	36	256 qam	24
Channel	Locked Status	RxMER (dB)	Pre RS Errors	Post RS Errors
1	Locked	36.6	10	0
2	Locked	36.3	16	0
3	Locked	37.3	7	0
4	Locked	37.6	8	0
5	Locked	37.6	22	0
6	Locked	36.3	16	0
7	Locked	37.3	21	0
8	Locked	37.3	23	0
9	Locked	37.3	22	0
10	Locked	37.3	6	0
11	Locked	37.3	8	0
12	Locked	37.3	16	0
13	Locked	37.3	7	0
14	Locked	37.3	11	0
15	Locked	37.3	5	0
16	Locked	37.3	10	0
17	Locked	36.6	9	0
18	Locked	37.6	12	0
19	Locked	37.6	10	0
20	Locked	37.6	9	0
21	Locked	36.6	10	0
22	Locked	37.3	6	0
23	Locked	37.3	10	0
24	Locked	36.6	9	0
1537000074.25512064 qam2
2394000044.1512064 qam4
3461999884.1512064 qam3
4602999794.25512064 qam1
3ATDMA0000
4ATDMA0000
Regards...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 34
Re: VM HUB3
Your stats are looking OK.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Darkmoon
  • 37
Message 4 of 34
Re: VM HUB3
Hi Mike.
Thanks for the detailed info I'll get checking tonight once I'm home.
Regards...
Darkmoon
  • 37
Message 5 of 34
Re: VM HUB3
Hardware version: 10
Software version: 9.1.1811.401
My BQM
Had to allow ICMP packets on my WAN interface so you'll see a red line for a while prior to pings and latency being plotted.  I guess I'll need to raise this with VM as reboots are generally either bad software (firmware) or failing hardware.
Regards...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 34
Re: VM HUB3
Same as mine.
Standard specification compliant: DOCSIS 3.0
It may be an idea to do a 5 minute off reboot at the top of the hour to timestamp the BQM, this should also show up on the Network Log; then 15 minutes or so later repost the Hub Network Log so that the times can be aligned.
Once that is done you can check the Network Log to see what is recorded against any reboots that happen.
Darkmoon
  • 37
Message 7 of 34
Re: VM HUB3
when i have check previously the only way I seen a reboot is the uptime. the log file does not log a so called "reboot" as it appears the hub crashes out, then  just boots up again for no apparent reason.
i'll just leave the monitor running, I should see any outages and then I'll take it to VM who can at the very least replace the hub for starters.  if they wont then looks like I'll be leaving VM.  I cannot have an unreliable service. full stop.
Regards...
  • 9K
  • 707
  • 1.64K
Message 8 of 34
Re: VM HUB3
If a hub reboots you will see at least one entry in the log with a date of 01/01/1970. You are just losing the connection to the CMTS and being reconstructed after a time.
Darkmoon
  • 37
Message 9 of 34
Re: VM HUB3
well the log I already posted, did not have a date of 1970 in it, yet the Info section in the hub states uptime as only 12 hours.  So I am unsure how a hub can have an uptime of 12 hours, yet it has not rebooted given your information.
Standard specification compliant	: DOCSIS 3.0
Hardware version	: 10
Software version	: 9.1.1811.401
Cable MAC address	: xxxxxxxxxxx
Cable modem serial number	: xxxxxxx
System up time	: 0 days 12h:25m:49s
Network access	: Allowed
Time	Priority	Description
09/09/2020 13:59:17	notice	LAN login Success;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
09/09/2020 13:59:13	Warning!	LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
09/09/2020 13:14:15	notice	LAN login Success;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
Regards...
Darkmoon
  • 37
Message 10 of 34
Re: VM HUB3
OK the logging is not showing rebooted of 1970.  maybe that was in an older firmware but my Hub is DEFINITALEY not reporting reboots.
I manually rebooted within the webgui.  it restarted the HUB.  logged into the HUB again.  only change was the uptime.  nothing was logged about the reboot at all today.
Maybe the error/warning log level has been changed so that reboots are now not logged?  can someone reboot their hub and see if reboot is logged (same firmware if possible?)
Cable MAC address	: xx:xx:xx:xx:xx:xx
Cable modem serial number	: xx:xx:xx:xx:xx:xx
System up time	: 0 days 0h:5m:33s
09/09/2020 13:59:17	notice	LAN login Success;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
09/09/2020 13:59:13	Warning!	LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
09/09/2020 13:14:15	notice	LAN login Success;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
07/09/2020 20:45:0	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
07/09/2020 17:30:41	notice	LAN login Success;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
07/09/2020 17:30:34	Warning!	LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
04/09/2020 19:54:22	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
04/09/2020 16:26:44	notice	LAN login Success;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
04/09/2020 01:11:35	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 13:59:48	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 02:24:11	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 00:32:41	notice	DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u+voc-b.cm modified;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 00:32:41	Error	DHCP REBIND WARNING - Field invalid in response;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 23:41:19	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 23:17:58	notice	LAN login Success;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
29/08/2020 21:10:43	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 08:27:46	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 16:50:27	notice	DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u+voc-b.cm modified;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 16:50:27	Error	DHCP REBIND WARNING - Field invalid in response;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 11:09:31	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
Regards...
