on 24-11-2023 10:33
My VM Connect app does not connect to my Hub. It does very occasionally, but most time that I open the app there is no connection.
Can I do something to fix this?
Can I control my WiFi another way?
on 24-11-2023 11:36
We prefer to login to the Hub menu at http://192.168.0.1/ and to manage the Wi-Fi directly from the Hub menus.
on 26-11-2023 17:31
Hi clarkmartin1968,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue with your connect app.
What is the error message you are getting when you attempt to connect?
^Martin
