those ports are for telephones, could run a ethernet cable around the house along side the telephone cables and can change the faceplates to include a ethernet port, this would require a punch down tool.
Since with ADSL you would have the router attached to one of the telephone ports with a microfilter, the other ports would also just be for telephone, unless moved router to that telephone port.
If need further explanation would be happy to assist
