Use of Wireless access point with Hub 3
I know this matter has been touched on before on this site, but I'm not completely clear ....
If I position the Wireless Access Point, the Unifi AC AC Pro, in a remote room in my house (which currently can't see the wifi signal from the hub 3) and attach it via a quality ethernet cable to my Hub 3  then things will work correctly. By work correctly, I mean that I will get a strong wifi signal in the remote room from the Unifi as well as a strong signal directly from the hub 3.
  • 12.25K
  • 948
  • 1.57K
Re: Use of Wireless access point with Hub 3
Yes, the Unifi will give a good Wi-Fi signal in that room (all interference excepted).
Good Wi-Fi from the Hub depends how you quantify 'Good'.
Mike Robinson
Hi MikeRobbo, Thanks for superfast response - hope my wifi signal will similarly be superfast!
I mean ... would there be any noticeable reduction in wifi signal/performance directly from the Hub3 between when it is connected to the unifi and when it is not. Hope that makes sense
  • 12.25K
  • 948
  • 1.57K
You shouldn't see any change in the Hub Wi-Fi.
Mike Robinson
