Upstream QAM intermittently drops to 32, upload speed reduced
carl_pearce
Community elder
My upload speed has been fluctuating between 30 - 80Mbps for the last few days (Usually see full 104Mbps consistently).
I've seen a number of T3 timeouts and the QAM drops across all five upstream channels to 32, then back up to 64.
04960000040.85120QAM 321
14310000040.35120QAM 322
23660000039.85120QAM 323
33010000038.85120QAM 324
42360000038.55120QAM 325
0ATDMA0000
3ATDMA0010
4ATDMA00300
BQM showing packet loss also:
Unsure if it's a coincidence, however Openreach have been in the area recently running new ducting in prep for fibre, so unsure if they may have disturbed some cabling.
Checked the online service status (freephone number also) and no reports of issues.
Carl.
EDIT: Just run an online check:
2 REPLIES 2
Paul_DN
Hi Carl,
Thank you for reaching out to us, sorry to see you have been facing an intermittent connection recently, I was able to locate you on our system with the details we have for you and can see there is an issue in the area.
The fault is an SNR (Signal to Noise Ratio) this is caused by a faulty/ exposed cable making noise on the network, You might find that your Virgin Fibre, Voice and Virgin TV services are intermittent, with the picture freezing or disappearing now and then. We are sorry and our engineers are working hard to resolve this ASAP, apologies for any inconvenience caused.
This was picked up on 09/09/23, the current estimated fix time is 11/09/23 @ 18:00, you can register for updates Via your Online Account
Paul.
Thanks, looks to be sorted, however appears to be a further update regarding Fault Ref: F010932975 that will be resolved by 18/09?
