jon_russ5
  • 19
Message 1 of 7
Upload speed slows down
Hi All,
I recently upgraded from 200 down/20 up to 350 down/36 up.
I was more than happy with 200 mbps down, and upgraded due to my work using a VPN/proxy server, and wanted faster upload speeds to improve speed when working from home.
However, I am seeing (using SpeedTest every 30 mins) that the upload speed drops to <20 mbps almost every day.  After I reboot the router this returns to the 37 mbps that I have been achieving.  I have attached an image of this (note, download speed is limited by 100 mbps network port on the Raspberry Pi).
I have also appended the HomeHub logs.
Any help gratefully received,
Jon
14982500001.538256 qam12
24102500001.538256 qam1
34182500001.240256 qam2
44262500001.738256 qam3
54342500002.240256 qam4
64422500001.738256 qam5
74502500001.540256 qam6
84582500001.938256 qam7
94662500001.538256 qam8
104742500001.938256 qam9
11482250000238256 qam10
124902500001.538256 qam11
135062500001.238256 qam13
145142500000.940256 qam14
155222500000.738256 qam15
165302500000.538256 qam16
175382500000.238256 qam17
185462500000.238256 qam18
195542500000.238256 qam19
205622500000.238256 qam20
215702500000.238256 qam21
22578250000038256 qam22
23586250000-0.238256 qam23
24594250000-0.738256 qam24
1Locked38.925967847
2Locked38.986948539
3Locked40.3247238610
4Locked38.9141898820
5Locked40.338788999
6Locked38.931678717
7Locked40.327858908
8Locked38.927548980
9Locked38.925678929
10Locked38.625298842
11Locked38.924918008
12Locked38.926688488
13Locked38.922937479
14Locked40.323367724
15Locked38.923767179
16Locked38.924486983
17Locked38.926937148
18Locked38.926816788
19Locked38.624216889
20Locked38.923406537
21Locked38.922627038
22Locked38.921276818
23Locked38.920827156
24Locked38.921616696
16029974253.5512064 qam5
1ATDMA0010
Tags (1)
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Message 2 of 7
Re: Upload speed slows down
@jon_russ5 wrote:
Hi All,
Jon
1Locked38.925967847
2Locked38.986948539
5Locked40.338788999
6Locked38.931678717
7Locked40.327858908
8Locked38.927548980
9Locked38.925678929
1ATDMA0010
Considering you only have one upstream channel, when you should have four, it explains why you have an issue with upload speed.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 3 of 7
You only have one Upstream Channel, you should have four and the Power Level on that one Channel is too high.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
jon_russ5
  • 19
Message 4 of 7
Thank you.
For info, I have just rebooted the router and get all 4 channels back - but this will likely go back to 1 tomorrow:
16029976651512064 qam5
23940016251512032 qam8
34620004851512032 qam7
45370024951512064 qam6
3ATDMA0000
4ATDMA0000
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Message 5 of 7
@jon_russ5 wrote:
Thank you.
3ATDMA0000
4ATDMA0000
The 'QAM' level is off on two channels so it appears you have an issue with your line.
The power levels are also too high which won't help things.
gary_dexter
  • 28.86K
  • 1.76K
  • 3.77K
Message 6 of 7
It’s also worth noting that a VPN is likely to slow your connection down depending what bandwidth restrictions they’ve implemented.
jon_russ5
  • 19
Message 7 of 7
Yes - understood.
However, speed tests have been conducted on personal IT without the VPN, etc.
Many thanks,
Jon
