AndrewChecks
Upload speed dropping to 0
Recently, i've been experiencing a major issue where the internet upload speed will intermittently and repeatedly drop down to 0, or very low (usualy around 2-3mbps)
My download is fine, maintaining a 65-70mbs but whereas I usually have 35-40mbs upload, throughout the day at random times it significantly drops, quite often going as low as 0.09mbs.
I have called the free and automated service and it says there are no issues with the service in the area. I've tried resetting the router and checking the cables.
1258750000-2.240256 qam16
2138750000-0.540256 qam1
3146750000-0.740256 qam2
4154750000-0.940256 qam3
5162750000-140256 qam4
6170750000-0.940256 qam5
7178750000-0.740256 qam6
8186750000-0.940256 qam7
9194750000-140256 qam8
10202750000-140256 qam9
11210750000-1.240256 qam10
12218750000-1.440256 qam11
13226750000-1.540256 qam12
14234750000-1.540256 qam13
15242750000-1.940256 qam14
16250750000-240256 qam15
17266750000-2.540256 qam17
18274750000-2.940256 qam18
19282750000-2.940256 qam19
20290750000-340256 qam20
21298750000-340256 qam21
22306750000-3.540256 qam22
23314750000-3.439256 qam23
24322750000-3.238256 qam24
AndrewChecks
Re: Upload speed dropping to 0
12360000045.5512032 qam9
24310002946.8512064 qam2
33010000546.3512064 qam4
43660000046.8512064 qam3
54960007246.5512064 qam1
1ATDMA0060
2ATDMA0050
3ATDMA0020
4ATDMA0020
5ATDMA0010
  • 1.85K
  • 115
  • 425
Super solver
The figures mentioned are a bit odd, it would he helpful to know if the speed the the Hub is correct and then move on to your device.
Can you run a test with the link below.
Once the test starts ,   click on Run full test   this adds in the details for upstream speeds.
AndrewChecks
  • 1.85K
  • 115
  • 425
Super solver
Hub speed is fine for the M500 service.
But it looks like your computer is connected to the Hub via a 100Mb/s connection - hence the 79.6 Mb/s downstream rate.
If your computer has a 1Gb/s network socket and is directly ethernet connected to the Hub, suspect a faulty network cable.
If the computer is connected via WiFi, 10/100 switches or AV600 type power line adaptors or a USB to ethernet adaptor with a 10/100 socket then this is what is limiting the computers download speeds.
Kath_F
  • 34.71K
  • 1.33K
  • 2.81K
Hi AndrewChecks,
We're sorry to hear you're having an issue with your upload speeds. Taking a look at things this end, I can see all your signal and power levels are within range. There is no open area fault affecting you either.
I can see your devices are connected via WiFi. Are you having the upload speed issue on other devices too or just the computer?
Pop back and let us know.
Kath_F
