rfrost
Message 1 of 5
Upload problems 22nd June 2021
There seems to be upload speed problems today in our location PO6 2JH.
Does anyone know if and when the problem may be resolved?
  • 6.46K
  • 1.01K
  • 1.6K
Message 2 of 5
Re: Upload problems 22nd June 2021
Hi rfrost,
Have you looked at Check service status at the top of the page? You can also a run a test on your equipment from there.
If nothing is showing  you could also try the  Service Status number  0800 561 0061.  This often gives details of more local issues down to postcode level.
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
rfrost
Message 3 of 5
Just checked service status and have confirmation of broadband problems in my area, thanks for your help.
rfrost
Message 4 of 5
Broadband functioning is back again, speed test 60/20 so we are happy again.
  • 6.46K
  • 1.01K
  • 1.6K
Message 5 of 5
Hi again rfrost,
Thanks for the update.
Good to hear it's all up and running properly now.
Dave
