  • 141
  • 9
Up to speed
Message 1 of 12
Upgraded to Gig 1 but not much faster than before
Upgraded to Gig 1 from M200 but not much faster than before I was getting around 210 download and expected much more on Gig 1
Installed it today but only getting high 200's on both my Laptop with 866 wireless card and on PC's with Gig Ethernet ports
Here are  my stats
Cable Modem Status
Item
Status
Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview
Downstream
Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
 Refresh data
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
10.699997
40.366287
QAM256
1
2
147000000
10.699997
40.366287
QAM256
2
3
155000000
10.599998
40.366287
QAM256
3
4
163000000
10.699997
40.946209
QAM256
4
5
171000000
10.599998
40.946209
QAM256
5
6
179000000
10.699997
40.366287
QAM256
6
7
187000000
10.900002
40.366287
QAM256
7
8
195000000
11.000000
40.366287
QAM256
8
9
203000000
11.099998
40.366287
QAM256
9
10
211000000
11.199997
40.946209
QAM256
10
11
219000000
11.199997
40.946209
QAM256
11
12
227000000
11.099998
40.366287
QAM256
12
13
235000000
11.099998
40.946209
QAM256
13
14
243000000
10.699997
40.366287
QAM256
14
15
251000000
10.500000
38.983261
QAM256
15
16
259000000
10.199997
40.366287
QAM256
16
17
267000000
10.300003
40.946209
QAM256
17
18
275000000
11.000000
40.946209
QAM256
18
19
283000000
10.900002
40.946209
QAM256
19
20
291000000
11.000000
40.366287
QAM256
20
21
299000000
10.699997
40.946209
QAM256
21
22
307000000
10.400002
38.983261
QAM256
22
23
315000000
10.400002
40.366287
QAM256
23
24
323000000
11.000000
40.366287
QAM256
24
25
331000000
11.199997
40.366287
QAM256
25
26
339000000
11.099998
40.366287
QAM256
26
27
347000000
11.300003
40.366287
QAM256
27
28
355000000
11.400002
40.366287
QAM256
28
29
363000000
11.199997
40.366287
QAM256
29
30
371000000
10.800003
38.983261
QAM256
30
31
379000000
10.900002
40.366287
QAM256
31
  • 141
  • 9
Up to speed
Message 2 of 12
Re: Upgraded to Gig 1 but not much faster than before
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
159
96
4K
1880
QAM1024
759
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
159
Locked
8.0
21529800
0
Refresh data
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
43.520599
5120 KSym/sec
64QAM
5
2
39400000
43.770599
5120 KSym/sec
64QAM
4
3
46200000
44.270599
5120 KSym/sec
64QAM
3
4
53700000
45.270599
5120 KSym/sec
64QAM
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
1
0
2
US_TYPE_STDMA
0
0
1
0
3
US_TYPE_STDMA
0
0
1
0
4
US_TYPE_STDMA
0
0
1
0
  • 11.7K
  • 913
  • 1.51K
Message 3 of 12
Your Downstream Power Levels are too high.
This will need an engineer to put right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
  • 141
  • 9
Up to speed
Message 4 of 12
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
a69834ncxv9873254k;fg87ds
SFID
636
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
635
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
 I  tried Sam Knows real speed and got this
Any help or advice is much appreciated - Many thanks Paul
  • 24.57K
  • 1.41K
  • 3.12K
Message 5 of 12
Your downstream levels are too high there so they’ll need adjusting by an engineer.
That aside, don’t expect speeds much quicker than that over WiFi.
  • 141
  • 9
Up to speed
Message 6 of 12
Thanks for the very fast reply Mike what levels should they be at?
  • 11.7K
  • 913
  • 1.51K
Message 7 of 12
Downstream -6dBmV to +10dBmV
Mike Robinson
  • 141
  • 9
Up to speed
Message 8 of 12
Thanks Mike what about the upstream?
  • 24.57K
  • 1.41K
  • 3.12K
Message 9 of 12
Upstream levels are fine and within spec.
  • 211
  • 24
Superfast
Message 10 of 12
Strange thing W-Fi. I am only on the 350 package but easily get 390Mbs on Wifi - All day everyday
Virgin 350 Hub 3, 3 x V6, 2 x Asus AX56 MESH
