Message 1 of 8
Upgraded router and WIFI keeps dropping
Please can someone help!? Virgin recently sent the Hub4 which I subsequently installed and have the following issues:
- The WIFI keeps dropping on all portable devices, including the TV (anything connected with an ethernet cable works seamlessly
- The range of the new router is dismal compared to the previous version
- Getting hold of a technical team is impossible
If anyone can help with any of the above, that would be greatly appreciated
  • 24.72K
  • 1.43K
  • 3.14K
Message 2 of 8
Re: Upgraded router and WIFI keeps dropping
What are wired speeds and connectivity like?
Message 3 of 8
Its seems absolutely fine when the connection is there
  • 24.72K
  • 1.43K
  • 3.14K
Message 4 of 8
If it’s just Wi-Fi there’s little can be done.
Have you split the Wi-Fi bands and changed to less congested channels?
Message 5 of 8
I have not; any guidance on how best to do that?
  • 24.72K
  • 1.43K
  • 3.14K
Message 6 of 8
Login to the hubs admin page and go to the wireless settings and you can make few changes there
Message 7 of 8
Thanks very much; once in, how do I change the channel sit up?
  • 24.72K
  • 1.43K
  • 3.14K
Message 8 of 8
You choose a channel from the drop down on the same page.
You need to use a Wi-Fi scanner first to determine the best channel to use.
