Hi all,
I have recently be upgraded to the M350 programe, and I can confirm using wifi on my ipad that I am recieving this.
However, my desktop computer is locked at 100 mbps.
*I am using a cat7 cable straight to the router
*I have a compatible nic in terms of it can take more than 100 mbps
*I am buying a second cable to check if this is the issue (I doubt it, but hey)
*I have updated drivers on the nic to the latest ones
* I have made sure auto disable gigabit is turned off under advanced settings on ethernet
I just want to make sure there is not something with the modem that I am missing, some setting that locks the ethernet port to 100 mb or something. Of course it could be the cable, but it is new enough only a few months, and gold plated / high quality.
Any help appreciated!!
