@JINNY2 wrote:
Thanks, what do you mean by out of spec? Does the firmware need upgrading, engineer visit or remote update from Virgin?
Right now I'm using it in modem mode and have the tp link running to give the WiFi range around house.
The downstream power levels should be -6 to +10 to be spec, 0dB is optimal.
These can be adjusted by:
- Fitting an attenuator between the HUB and cable to the wall socket to reduce the power levels.
- Adjusting the power levels in the local cabinet.
Regardless this should only be done by an engineer.
