Settling in
Message 1 of 9
Upgrade from M100 to M350, how long should it be before speed increases?
I have recently upgraded broadband from M100 to M350.  I received an email to say that the upgrade had been actioned, but I am still only getting M100 speeds.
How long should the process take?
  • 24.47K
  • 1.4K
  • 3.11K
Message 2 of 9
Re: Upgrade from M100 to M350, how long should it be before speed increases?
Have you rebooted the hub?
Settling in
Message 3 of 9
TRe: Upgrade from M100 to M350, how long should it be before speed increases?
Yes, several times.
  • 11.61K
  • 899
  • 1.48K
Message 4 of 9
Re: TRe: Upgrade from M100 to M350, how long should it be before speed increases?
Copy and paste the contents of the Configuration tab onto here, if you get a yellow warning click the Post button again. Please do not use screen grabs.
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
Settling in
Message 5 of 9
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057+voc-b.cm
SFID123894
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID123893
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
  • 11.61K
  • 899
  • 1.48K
Message 6 of 9
SFID123894
Min Traffic Rate0
SFID123893
Min Traffic Rate0
Your Hub is still provisioned for the 100Mbs service.
Mike Robinson
  • 3.52K
  • 273
  • 479
Superfast
Message 7 of 9
Just leave it overnight and check it tomorrow.
Settling in
Message 8 of 9
So do I need to phone and chase or will it be done automatically?
  • 14.73K
  • 620
  • 1.42K
Message 9 of 9
You need a hub 3.
