LondonLiz
  • 13
Unstable connection - Hub 4 seems to make it worse
I have always had trouble with regular unstable connections. Despite being in a small flat I often get a weak signal, I have moved the router but since getting a Hub 4 it seems to be worse.
The odd thing is that if I do a speed test its always fine
Any tips - its making work Zoom calls almost impossible
Liz
gary_dexter
  • 30.64K
  • 1.9K
  • 4.07K
Re: Unstable connection - Hub 4 seems to make it worse
Is it better on a wired connection?
LondonLiz
  • 13
The trouble is I can't use a wired connection as the hub is out in the hall by the flat front door
gary_dexter
  • 30.64K
  • 1.9K
  • 4.07K
Have you done any optimisation of the wifi on the hub?
Split the wifi bands, chosen less congested channels etc.?
Paulina_Z
  • 515
  • 16
  • 34
Hi @LondonLiz,
Welcome back to our Community Forum! Thank you for posting, we really appreciate it.
I'm sorry to hear that you're experiencing some connection issues with your Hub 4! This is definitely not what you want to be experiencing.
I have managed to locate your account from the information you provided on our Forums and was able to take a look to see if there are any issues.
Would you be able to reboot your Hub and let us know if this helped with the connection issue please?
Keep us updated on how you get on.
Paulina_Z
LondonLiz
  • 13
Thanks - I have only had one Zoom call today but there were no problems so thank you that might have done the job
Liz
