forumarchive,nothingtosee,
georgeZZzz
  • 10
Message 1 of 14
Unstable Connection and Speed during meetings when woking from home
For the last 1-2 months or so, very glitchy during intenet meetings using Skype for business or Zoom, especially in the afternoon. I use wired connection to hub3.0 directly. very annoying!!!
georgeZZzz
  • 10
Message 2 of 14
Re: Unstable Connection and Speed during meetings when woking from home
  • 20.53K
  • 2.18K
  • 3.63K
Message 3 of 14
What do you mean by "glitchy"? Simple thing... have you tried a new Cat5e/6/7 ethernet cable - they do sometimes "fail".
That said, your down power levels are near the top of the recommended range and you have a few Up T3 timeouts. To get a bigger picture can you post up the network logs as well.
Also... If you haven’t already, set up a free and secure “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph” (as per instructions on the TB website) when it starts to develop.
georgeZZzz
  • 10
Message 4 of 14
Thanks John for you quick reply
"glitchy" means breaking up a lot when talking and listening to others, and sounded like Robot and hard to understand, I tried differernt headsets, same result.
yes i tried uploading monitoring in the first post but failed for some reason.
georgeZZzz
  • 10
Message 5 of 14
31/01/2021 11:09:13noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2021 05:09:20noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2021 05:09:20ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 04:02:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 17:47:50noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 08:05:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:59Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2021 12:50:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2021 11:28:27noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2021 11:28:27ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 12:47:39noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 12:29:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2021 15:27:46noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2021 15:16:22Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2021 15:12:5noticeReceived REG-RSP while in REG-HOLD1 state;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:0Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 07:46:13noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 07:46:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 21:26:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 19:46:14noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
georgeZZzz
  • 10
Message 6 of 14
By the way, my wife is woking from home and having internet calls as well, and kids are taking online course from school, but it always happened in the afternoon, morning is fine.
We used BT BB 76M last year, no these annoying issues at all.
  • 20.53K
  • 2.18K
  • 3.63K
Message 7 of 14
Right. I can look at the images but they will be rejected as they contain your i.p. address. Can you post the link to "share live graph" - where the TB site strips that out.
That said it looks awful and suggests to me that you may have a utilisation issue - too many users connecting at peak times. But only VM can say whether that is the case or there is some other issue (like your power levels) that is causing the issue.
I will flag for VM to come here and advise you - keep checking back
georgeZZzz
  • 10
Message 8 of 14
My Broadband Ping - VM
Alex_RM
  • 4K
  • 229
  • 304
Message 9 of 14
Hi georgeZZzz,
Thanks for posting and sorry to hear you're having some issues with your connection.
I've been able to locate your account using your forum details and can see that you're currently affected by an area congestion issue. We are planning to undertake some upgrades to support the increased demand for our services in your area. When completed, any slow broadband speeds and buffering on TiVo apps you may be experiencing (particularly at peak times) will be resolved.
The estimated fix date/ time is currently 8th February, fault reference F008074424.
Alex_Rm
  • 20.53K
  • 2.18K
  • 3.63K
Message 10 of 14
Oh dear 😞
