  • 130
  • 22
Up to speed
Message 1 of 7
Unable to reconnect TV to Hub 3 over WiFi
I have a Samsung TV that was connected over WiFi to our Hub 3 - iPlayer, Netflix and Spotify etc all worked perfectly.
This TV isn't our main TV and we don't use it all the time -  but when I switched it on a few days ago I could see that it wasn't connected to the internet. When doing a scan, my network is showing up with a full signal - but when I put the password in, it just won't connect. I have tried pairing via WPS but this also fails. I connected via ethernet and all worked ok.
I've been trying to understand why this is happening. The only thing that I can think of is that we recently had an ongoing area broadband that was on and off over a 6 week period. Internet has been stable for a couple of weeks now and wifi on all other devices anywhere in our house is spot on.
The one odd thing is that the light on the Hub 3 that always used to be really bright white, is now more of a dull yellow/green colour. Possibly a red herring??
Any suggestions welcomed to try and set my TV connected over WiFi again...
  • 1.6K
  • 69
  • 117
Message 2 of 7
Re: Unable to reconnect TV to Hub 3 over WiFi
Hello heavysoul
Thank you for you post, this is very strange! I am sorry to hear you have this issue, I have a few questions please?
What is the TV model number
Does it use a wireless network card or is this built in Wifi connection
Do any other devices struggle to connect?
Thanks Joe_F
  • 130
  • 22
Up to speed
Message 3 of 7
@Joe_F wrote:
Hello heavysoul
Thanks Joe_F
Hi Joe... the model number is - Samsung UE40MU6400 - I've had it 18 months.
WiFi is built in. It connected first time at setup and have not had a problem with watching iPlayer etc until now.
All other devices - iPhones, iPads, laptops, Kindles, 4 x Sonos all connect without a problem.
  • 1.6K
  • 69
  • 117
Message 4 of 7
OK thanks, I am unsure if you can give this a try for me just to rule out the actual WiFi on the TV, Are you able to maybe setup a hotspot from an iPhone or other device and see if the TV can connect to that, Just want to rule that out as an issue.
Thanks Joe_F
  • 130
  • 22
Up to speed
Message 5 of 7
Thanks Joe_F
Now why didn't I think of trying that! So yes... just tried connecting to my iPhone hotspot - it won't connect!
So something going on with the TV then which I will need to investigate.
Many thanks for responding so quickly.
  • 130
  • 22
Up to speed
Message 6 of 7
Thanks Joe_F
And a quick search re issues with Samsung TVs not connecting to WiFi found an easy solution... hold the standby button on the TV remote for 5 seconds which resets/reboots the TV! I then connected without any issues! YAY!!
  • 2.56K
  • 150
  • 319
Message 7 of 7
Thanks so much for popping back with that resolution @heavysoul -hopefully that will help out other members of the Community that also may be having the same issue 🙂
Cheers
Katie - Forum Team
