LJMallin
Just joined
Unable to connect to hub3
I was frustrated and lazy last night so instead of turning off the internet for individual devices I turned both bandwidths off.... Now I can't connect at all 🤦
Have turned off the router for 10 minutes and restarted. Have also pressed the restart button to no prevail!
How do I get my internet back!?!
Tags (4)
lotharmat
  • 937
  • 70
  • 141
Well-informed
Re: Unable to connect to hub3
Can you try a pin-hole reset?
Unplug all ethernet cables
With the power on and the co-ax connected; press and hold the reset switch with a paperclip or sim removal tool for at least 60 seconds.
Allow 10 minutes to reboot, reset and stabilise
you'll need to use the default WiFi Password to get back in and the default 8-digit code to get back into the Hub
