Unable to access hub settings
Hey guys
So I'm unable to access the hub settings. I'm using the correct password on the bottom of the unit but it just keeps coming up password incorrect.
Anyone else had this issue
Thanks in advance for the help
  • 9
Re: Unable to access hub settings
On the bottom of the router there is a settings password which is usually numbers. That’s the one you need to log in
  • 11.64K
  • 1.19K
  • 1.88K
Is it a Hub3?
Do a factory reset – EXACTLY this way.
With the Hub "on" push in the pin on the back/side/bottom of the Hub with the end of a paperclip (bigger item like ball point pens may not press it in far enough) until you feel it at the “stop point” and hold it there firmly for a "timed" 60 seconds do NOT restart the Hub after that. Leave it 5' or so to stabilise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card. Make sure you use the wifi one for devices connecting to the wifi and the settings one to access the Hub.
If that doesn’t sort it - call it in as faulty.
