  • 9
Message 1 of 17
Ultra Slow Broadband
For a couple of weeks now the download speed when I run Ookla has dropped to 7Mbps and devices are constantly buffering. I am on a 350Mbps contract. Strangely, the upload speed is >75Mbps. has anybody else seen this problem?
  • 11.81K
  • 925
  • 1.52K
Message 2 of 17
Re: Ultra Slow Broadband
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
  • 9
Message 3 of 17
8.2Mbps on Speedtest (37 upload) direct connected to the hub with fast desktop.
  • 11.81K
  • 925
  • 1.52K
Message 4 of 17
With that device still connected Can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed’ as for the cable connected device you used for the speed test ?
Mike Robinson
  • 9
Message 5 of 17
Says 100Mbps
  • 11.81K
  • 925
  • 1.52K
Message 6 of 17
Your Contract Speed is 350Mbs
You get 8.2Mbs
The testing Device  & Cable combination is limited to 100Mbs
Can you try again with a different cable please ?
Mike Robinson
  • 24.7K
  • 1.42K
  • 3.14K
Message 7 of 17
Try a different cable that’s at least CAT5E or better.
  • 11.81K
  • 925
  • 1.52K
Message 8 of 17
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
Then
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Mike Robinson
  • 9
Message 9 of 17
Hi Guys,
In answer to a previous post re replacing the cat 5 cable - I have tried the speedtest on several devices in the house and I get exactly the same result. These are all on ethernet.
I will have a go at the BQM set up in a mo.
402750000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
14027500003.740256 qam25
21867500004.340256 qam7
31947500004.140256 qam8
42027500004.140256 qam9
5210750000440256 qam10
62187500003.740256 qam11
72267500003.540256 qam12
82347500003.440256 qam13
92427500003.240256 qam14
102507500003.240256 qam15
112587500003.440256 qam16
122667500003.440256 qam17
132747500003.440256 qam18
142827500003.740256 qam19
152907500003.740256 qam20
162987500003.740256 qam21
173067500003.940256 qam22
18314750000440256 qam23
19322750000440256 qam24
204107500003.740256 qam26
214187500003.740256 qam27
22426750000440256 qam28
234347500004.140256 qam29
244427500004.140256 qam30
1Locked40.380
2Locked40.9110
3Locked40.9210
4Locked40.310
5Locked40.950
6Locked40.350
7Locked40.360
8Locked40.360
9Locked40.950
10Locked40.350
11Locked40.340
12Locked40.380
13Locked40.360
14Locked40.960
15Locked40.950
16Locked40.3190
17Locked40.330
18Locked40.340
19Locked40.360
20Locked40.370
21Locked40.910
22Locked40.360
23Locked40.390
24Locked40.910
  • 24.7K
  • 1.42K
  • 3.14K
Message 10 of 17
Wired direct to the hub or via a switch or powerline/booster plug?
