BeechyUK
  • 6
Message 1 of 11
Trouble with Packet Loss / Latency - Hub 4
Hi there,
I've had my 1Gig internet for about a month, and the Superhub doesn't ever seem to have worked properly. Wifi connections have been patchy and streaming suddenly would just stop before starting again.
Most recently. wired connections are now suffering too. While the speed is OK, there are significant lag / latency problems which make playing online games impossible.
I did NOT experience any of these issues with the Superhub 3 - I can therefore only conclude that the new hub is to blame.
Any suggestions are welcome - I've done the usual of resetting the router, turning it off and on again. I had a look around and it appears that this is a reasonably well known issue but I couldn't quite work out what people were doing about it?
Downstream channels below - seems like they might help someone! Note this was taken around 30 minutes after a reboot.
3.0 Downstream channels
1Locked38.60537700
2Locked38.98326100
3Locked38.98326100
4Locked38.98326100
5Locked38.98326100
6Locked38.60537700
7Locked38.98326100
8Locked38.98326100
9Locked38.60537700
10Locked38.98326100
11Locked38.98326100
12Locked38.98326100
13Locked38.98326100
14Locked38.98326100
15Locked38.60537700
16Locked38.98326100
17Locked38.60537700
18Locked38.60537700
19Locked37.63627600
20Locked37.35598800
21Locked37.63627600
22Locked38.60537700
23Locked38.98326100
24Locked38.98326100
25Locked38.60537700
26Locked38.98326100
27Locked38.98326100
28Locked38.60537700
29Locked38.98326159
30Locked38.98326100
31Locked38.60537700
3.1 Downstream channels
159964K1880QAM2048759
159Locked39-6.212533430
JitteryPinger
  • 1.74K
  • 189
  • 348
Super solver
Message 2 of 11
Re: Trouble with Packet Loss / Latency - Hub 4
Can you share upstream channel info too please, also setup a BQM by following instructions below,
To do this first register here https://www.thinkbroadband.com/register , Once register go here https://www.thinkbroadband.com/broadband/monitoring/quality
Click on Create a new monitor, Enter a name for your Graph then Enter your IP address (this should already have detected your IP for you)
Select Cable Broadband as Type, Then enter postcode (optional), Allow in trends (optional)
Then Create
Then find your BQM here https://www.thinkbroadband.com/broadband/monitoring/quality/list
Click on Share Live Graph, then right click in the direct link box, click select all, right click again and copy into a reply.
If I've helped please let me know 🙂 Matt
A 10+ Year Virgin Media veteran, been here through the Up's and the Down's and Down's....
Gigabit 5G Vodafone 5G EE BQM Hub 4 BQM Hub 3 BQM Hitron CGNV4 BQM TT BQM
Technical Support - AV & Networking - Customer Service - Finance - Culinary - Construction
BeechyUK
  • 6
Message 3 of 11
Hi Matt,
Thanks for the quick reply! I did actually set up a BQM just as I saw it might be needed, it's still early but it doesn't appear to be great..:-D
https://www.thinkbroadband.com/broadband/monitoring/quality/share/19260f6b512553c6c6519666b7f4971043e7d5da
3.0 Upstream channels
13260000049.0205995120 KSym/sec64QAM5
23940000049.2705995120 KSym/sec64QAM4
34620000049.2705995120 KSym/sec64QAM3
45370000049.7705995120 KSym/sec64QAM2
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
JitteryPinger
  • 1.74K
  • 189
  • 348
Super solver
Message 4 of 11
So first thing I noticed from your downstream is that your hub is connecting a lower modulation that it should be, which will mean slower Download speeds than usual.
So first thing we should try is turning off the hub, check all connections are tight and power back on.
Then repost downstream stats in full .
BeechyUK
  • 6
Message 5 of 11
Hi Matt,
I turned it off, checked the connections. All seemed OK but I unplugged / plugged back in to be sure.
I've posted the whole downstream thing below - it doesn't obviously seem to have made a difference to the bit you quoted but let me know!
James
11390000002.00000038.983261QAM2561
21470000001.40000238.983261QAM2562
31550000001.50000038.605377QAM2563
41630000001.20000138.605377QAM2564
51710000000.79999938.983261QAM2565
61790000000.50000038.605377QAM2566
71870000000.79999938.983261QAM2567
81950000000.70000138.983261QAM2568
92030000000.79999938.605377QAM2569
102110000000.59999838.605377QAM25610
112190000000.29999938.605377QAM25611
122270000000.09999838.983261QAM25612
13235000000-0.40000238.605377QAM25613
142430000000.00000038.983261QAM25614
15251000000-0.09999838.605377QAM25615
16259000000-0.40000238.605377QAM25616
17267000000-0.70000138.983261QAM25617
18275000000-0.59999838.605377QAM25618
19283000000-2.20000137.636276QAM25619
20291000000-2.40000237.636276QAM25620
21299000000-1.40000237.636276QAM25621
22307000000-0.70000138.605377QAM25622
233150000000.09999838.983261QAM25623
243230000000.00000038.605377QAM25624
25363000000-0.20000138.605377QAM25625
26371000000-0.50000038.983261QAM25626
27379000000-0.09999838.605377QAM25627
28387000000-0.29999938.605377QAM25628
29395000000-0.40000238.983261QAM25629
30403000000-1.09999838.605377QAM25630
31411000000-2.09999838.605377QAM25631
1Locked38.98326100
2Locked38.98326100
3Locked38.60537700
4Locked38.60537700
5Locked38.98326100
6Locked38.60537700
7Locked38.98326100
8Locked38.98326100
9Locked38.60537700
10Locked38.60537700
11Locked38.60537700
12Locked38.98326100
13Locked38.60537700
14Locked38.98326100
15Locked38.60537700
16Locked38.60537700
17Locked38.98326100
18Locked38.60537700
19Locked37.63627600
20Locked37.63627600
21Locked37.63627600
22Locked38.60537700
23Locked38.98326100
24Locked38.60537700
25Locked38.60537700
26Locked38.98326100
27Locked38.60537700
28Locked38.60537700
29Locked38.98326100
30Locked38.60537700
31Locked38.60537700
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked39-6.291699110
gary_dexter
  • 28.96K
  • 1.77K
  • 3.79K
Message 6 of 11
Your DOCSIS 3.1 channel is still out of sync and below spec.
You'll need an engineer to resolve.
BeechyUK
  • 6
Message 7 of 11
Thank you both!
Not necessarily the answer I wanted, but perhaps the answer I expected 🙂
Really appreciate you both looking into this.
James
Chris_W1
  • 3.62K
  • 160
  • 211
Message 8 of 11
Hi BeechyUK, thanks for the message. I have looked into this for you and can you let us know how it goes with the engineer tonight? ^Chris
BeechyUK
  • 6
Message 9 of 11
Hi Chris,
Thanks for checking in.
The engineer came and replaced some old cable which unfortunately didn't help. I bought a router and used the Hub in modem mode as that seemed to have worked for some people, that hasn't done anything either. Here's the BQM. - https://www.thinkbroadband.com/broadband/monitoring/quality/share/19260f6b512553c6c6519666b7f4971043...
I'm at a bit of a loss at the moment - I'm trying to arrange another engineer visit but my connection is pretty useless at the moment except for basic web browsing etc - anything that requires a constant flow of data doesn't work properly at all.
James
Paul_DN
  • 5.24K
  • 308
  • 548
Message 10 of 11
Hi BeechyUK,
Thank you for reaching out to us, I am sorry to hear your connection still isn't great after the technician has been, I have had a look our end and cannot see any issues at all, can you remove your router and put ours back in router mode so I can run further checks as we cannot see the router when in modem mode?
Paul.
