Just joined
Too many devices??
Please can someone help, whenever I try and use Virgin Media TV GO it says "too many devices". When I check which devices are registered one of them is the same device that i'm using to try and access TV Go??? I don't get it? + it says I have to wait 14 days to be able to remove any devices. But the device I want to use is the same device I'm using and which is registered.
Is there someone out there who works for Virgin that can just clear the devices so I can try from scratch??
  • 11.49K
  • 503
  • 750
Re: Too many devices??
Hi ckaceshot,
Welcome to the Community!
I'm really sorry to hear you're having trouble with TV Go.
I'd like to check this out for you but I can't seem to locate your account. I've sent you a private message (purple envelope at the top right of your screen) so I can grab some details.
Speak soon
Josh
  • 5
I am trying to watch TV on my PC and it says i have too many devices registered. How to I see which devices are registered and delete the ones I don't require.
  • 1.42K
  • 99
  • 132
Hey biggrah,
To check your registered devices, please follow the below instructions
Log in    >      Settings       >     Device management
This will then display all of the devices that are registered to the app but you can only change one device a month, so please make sure that you delete the right device.
Steven_L
  • 5
Have now spoken to someone on the Tech phoneline and he has changed something. and everything is now working ok.
  • 1.5K
  • 81
  • 118
Brilliant, thanks for taking the time to let us know 🙂
Melissa
