nikbower
  • 67
Message 1 of 55
Think I need a replacement Hub
My broadband is solid when it's working and wifi is fine throughout the house, but the connection keeps going down every day or two.  I've checked all physical connections, they're fine.  Usually the problem is fixed by restarting the hub, though sometimes I have to restart a few times to get it working again.  I've reset the hub to factory settings a couple of times too, but the issues persist.  I really think the hub might just have reached the end of its life.  How can I get it replaced?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 55
Re: Think I need a replacement Hub
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
 In the URL box paste the link you copied and then click OK - you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click Post again.
nikbower
  • 67
Message 3 of 55
Hey Mike,
Thanks for your reply.  Yes, I always check service status first, but this keeps happening when the area is fine (and restarting hub fixes the problem immediately) so I do think it's an equipment issue.  I've checked all the physical connections inc coax into the house and into the router.
I'll set up the BQM and post results later today.
Thanks!
Nik
nikbower
  • 67
Message 4 of 55
14027500002.538256 qam25
2218750000440256 qam11
32267500003.938256 qam12
42347500003.538256 qam13
52427500003.538256 qam14
62507500003.238256 qam15
7258750000338256 qam16
8266750000340256 qam17
92747500002.938256 qam18
102827500002.738256 qam19
112907500002.938256 qam20
122987500003.238256 qam21
133067500003.238256 qam22
143147500003.238256 qam23
153227500003.238256 qam24
164107500002.538256 qam26
174187500002.538256 qam27
184267500002.538256 qam28
194347500002.538256 qam29
204427500002.238256 qam30
21450750000238256 qam31
224587500001.738256 qam32
234667500001.238256 qam33
24474750000138256 qam34
1Locked38.600
2Locked40.350
3Locked38.950
4Locked38.950
5Locked38.950
6Locked38.960
7Locked38.940
8Locked40.360
9Locked38.640
10Locked38.960
11Locked38.6110
12Locked38.960
13Locked38.940
14Locked38.950
15Locked38.6130
16Locked38.960
17Locked38.940
18Locked38.940
19Locked38.640
20Locked38.940
21Locked38.950
22Locked38.9170
23Locked38.640
24Locked38.970
nikbower
  • 67
Message 5 of 55
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46199981
4.275
5120
64 qam
3
2
39400056
4.275
5120
64 qam
4
3
53700002
4.275
5120
64 qam
2
4
60299996
4.275
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
nikbower
  • 67
Message 6 of 55
Time
Priority
Description
27/07/2020 16:18:52
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:35
critical
25/07/2020 20:56:23
notice
NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/07/2020 01:29:14
critical
22/07/2020 17:16:53
notice
22/07/2020 02:16:15
critical
18/07/2020 23:03:58
notice
18/07/2020 00:50:33
critical
17/07/2020 17:54:25
notice
16/07/2020 23:20:22
notice
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/07/2020 23:20:22
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/07/2020 09:33:24
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/07/2020 19:53:51
critical
15/07/2020 19:46:29
Error
12/07/2020 16:41:21
critical
11/07/2020 14:30:17
notice
11/07/2020 07:40:12
Error
07/07/2020 21:48:8
critical
07/07/2020 05:42:55
notice
07/07/2020 05:42:55
Error
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 55
@nikbower wrote:
Hey Mike,
Thanks!
Nik
Rebooting the Hub will force a renegotiation of the connection, thus fixing the problem short term but hides an external problem.
The sooner the better with the BQM.
  • 22.5K
  • 2.41K
  • 4.02K
Message 8 of 55
Stats all lookk ok. The BQM will reveal whether the issue is a network connection problem or just a wifi one.
Do ethernet connected devices also drop out at the same time as wifi ones do?
nikbower
  • 67
Message 9 of 55
Hmm, good question.  I only have one device on ethernet, which is a smart TV in the spare room, not sure I've checked that for the recent drop-outs.  I guess I can check that next time it happens - can I also plug a laptop into the ethernet after a drop-out to test whether the hard line's still working?
nikbower
  • 67
Message 10 of 55
