Terrible speed, potential network fault
lucianf
I've been experiencing an extremely slow broadband speed for a few weeks now.
I have an M350 package, previously speedtest would very consistently show speed in the 350 Mbps range, lately it's been around 8-11 Mbps so clearly something is off. No change in my setup, hub 3.0 in modem mode, running speedtest straight of hardwired router.
I found a similar older thread that based on the errors I see in the hub console (lots of alternating "RCS Partial Service"/"Lost MDD Timeout") suggested I post here and maybe a VM technician can have a look, presumably a fault in my area (happy to provide account details and MAC addresses via DM).
Errors go like this:
23/09/2023 23:39:19 Warning! RCS Partial Service;CM-MAC=xx;CMTS-MAC=yy;CM-QOS=1.1;CM-VER=3.0;
23/09/2023 23:39:18 Warning! Lost MDD Timeout;CM-MAC=cx;CMTS-MAC=yy;CM-QOS=1.1;CM-VER=3.0;
23/09/2023 23:37:57 Warning! RCS Partial Service;CM-MAC=xx;CMTS-MAC=yy;CM-QOS=1.1;CM-VER=3.0;
23/09/2023 23:37:57 notice LAN login Success;CM-MAC=xx;CMTS-MAC=yy;CM-QOS=1.1;CM-VER=3.0;
23/09/2023 23:36:27 Warning! RCS Partial Service;CM-MAC=xx;CMTS-MAC=yy;CM-QOS=1.1;CM-VER=3.0;
23/09/2023 23:36:26 Warning! Lost MDD Timeout;CM-MAC=xx;CMTS-MAC=yy;CM-QOS=1.1;CM-VER=3.0;
23/09/2023 23:36:0 Warning! RCS Partial Service;CM-MAC=xx;CMTS-MAC=yy;CM-QOS=1.1;CM-VER=3.0;
23/09/2023 23:35:58 Warning! Lost MDD Timeout;CM-MAC=xx;CMTS-MAC=yy;CM-QOS=1.1;CM-VER=3.0;
23/09/2023 23:35:14 Warning! RCS Partial Service;CM-MAC=xx;CMTS-MAC=yy;CM-QOS=1.1;CM-VER=3.0;
Lucian
1 ACCEPTED SOLUTION
Accepted Solutions
Hi lucianf,
Thanks for taking the time to contact us via the Community.
We're sorry to hear that you're having issues with your connection. Taking a look at things this end, any area fault has been closed now. Running further diagnostics, a few performance issues are being picked up. We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you.
I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
Kath_F
6 REPLIES 6
lucianf
11390000001.929256 qam1
21470000003.227256 qam2
3155000000426256 qam3
41710000002.724256 qam5
5179000000325256 qam6
61870000002.225256 qam7
71950000002.528256 qam8
82030000002.227256 qam9
9211000000226256 qam10
10219000000227256 qam11
112270000001.432256 qam12
122350000001.535256 qam13
132430000002.736256 qam14
142510000002.436256 qam15
152590000001.736256 qam16
162670000002.235256 qam17
172750000002.935256 qam18
182830000001.735256 qam19
192910000001.535256 qam20
202990000002.535256 qam21
213070000002.435256 qam22
223150000001.735256 qam23
233230000001.935256 qam24
1Locked29.81263860732396336
2Locked27.7-529146028592704930
3Locked26-176156233-551181896
4Locked24.1-919897378-309487106
5Locked25-517104730-708549487
6Locked25.7447925671506153246
7Locked28.6-743593072156936
8Locked27.8-9847054943692565
9Locked26.58135176731902143493
10Locked27.4162801489153072224
11Locked32.9296224871695
12Locked35517031199
13Locked36.36342757
14Locked36.35944708
15Locked36.35484650
16Locked35.77146706
17Locked35.76047595
18Locked35.56204507
19Locked35.75682471
20Locked35.58009503
21Locked35.77150470
22Locked35.77874850
23Locked35.582943784
13660000043.3512064 qam11
22360000043.3512064 qam13
33010002141.8512064 qam12
44309996945.8512064 qam10
54959997449512064 qam9
1ATDMA0010
2ATDMA0020
3ATDMA0010
4ATDMA0010
5ATDMA0020
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
xx
SFID224
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID223
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
ItemStatusCommentsAcquired Downstream Channel (Hz)
139000000
Locked
Ranged Upstream Channel (Hz)
36600000
Locked
Provisioning State
Online
Hero
Check 0800 561 0061 - there looks to be a significant noise fault ...
12Locked35517031199
13Locked36.36342757
14Locked36.35944708
15Locked36.35484650
16Locked35.77146706
Already have - they say no issue in my area & then hang up.
lucianf
FWIW VM support have mentioned there is an issue reported in my area (wonder why this not picked up by their own status checker?) and their network teams are now aware.  Then they offered:
- to help me set up my Wi-Fi with a single SSID and have me test from the same room as the hub (despite me initially mentioning I had a router hardwired to their hub in modem mode..)
- to replace my 3.0 hub with a hub 5 as this improves Wi-Fi speed (again not addressing my issue..)
- to send in "fresh signals from their end" and "changed bandwidth from 2.4Ghz to 5GHz which will massively improve on my services and resolve any intermittent issues if any" (their words) (I laughed hard on this one)
Still having higher hopes on someone from VM picking this up here.....
Hi lucianf,
Kath_F
