Message 1 of 8
Terrible intermittent connection both wireless and wired. TB linked
https://www.thinkbroadband.com/broadband/monitoring/quality/share/c3a85b5f7a5ab56b40d8fba4265ad07b08...
So. Past week it has been f*****g mental. Random drops. Random complete internet loss. All devices. Wired and wireless. Only things ive messed with are splitting up 2.4 and 5 for ranges and changing passwords as far as I recall. Ive been logging every loss or disconnection ive been experiencing just myself. Can only guess everyone else in the household. Any help greatly appreciated.
Edit. Cant log into my admin panel anymore. Havent for a day and a bit. Keep getting someone else is logged in. Considering im the only one who knows the admin password. But surprising.
  • 12.3K
  • 952
  • 1.58K
Message 2 of 8
Re: Terrible intermittent connection both wireless and wired. TB linked
Which Hub do you have ?
What is your contracted speed ?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Mike Robinson
  • 12.3K
  • 952
  • 1.58K
Message 3 of 8
Can you please
Mike Robinson
Message 4 of 8
Hub 3
M500 so I think average 362?
I have. Its saying internet is fine. There's a problem with television.
Probably shouldve grabbed all this info BEFORE I factory reset my hub. But hey ho. Here we are.
12827500004.938256 qam19
21387500006.440256 qam1
31467500006.138256 qam2
4154750000640256 qam3
51627500006.540256 qam4
61707500006.438256 qam5
71787500006.540256 qam6
81867500006.538256 qam7
91947500006.540256 qam8
102027500006.138256 qam9
11210750000638256 qam10
12218750000638256 qam11
132267500005.938256 qam12
142347500005.838256 qam13
152427500005.338256 qam14
162507500005.438256 qam15
17258750000538256 qam16
182667500005.138256 qam17
192747500004.838256 qam18
202907500004.938256 qam20
212987500004.938256 qam21
223067500004.538256 qam22
23314750000538256 qam23
24322750000538256 qam24
1Locked38.960
2Locked40.300
3Locked38.940
4Locked40.360
5Locked40.360
6Locked38.9150
7Locked40.360
8Locked38.950
9Locked40.3210
10Locked38.650
11Locked38.950
12Locked38.960
13Locked38.630
14Locked38.940
15Locked38.900
16Locked38.900
17Locked38.900
18Locked38.930
19Locked38.640
20Locked38.6110
21Locked38.960
22Locked38.600
23Locked38.950
24Locked38.600
Upstream
14619999146.3512016 qam1
22580000744.8512016 qam4
33260000446.3512016 qam3
43940001446.3512016 qam2
1ATDMA0010
3ATDMA0000
4ATDMA0000
Message 5 of 8
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
wrkldJKDHSUBsgvca69834ncxv987
SFID2706
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID2705
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
15/11/2020 23:33:30noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 22:43:1noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 11:23:1noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 11:23:1ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 07:02:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 18:19:45noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 04:06:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 23:54:12noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 23:54:9Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 21:32:27noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 05:55:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 01:45:47Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 00:54:53noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 00:54:53ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 00:26:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 00:21:39Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 00:21:38criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 00:21:38Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 00:21:33criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 12.3K
  • 952
  • 1.58K
Message 6 of 8
Your Power Levels all look OK, tour Upstream Power Levels however are are all too low at 16 QAM, they should be at 64 QAM.
Try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
Mike Robinson
  • 11.51K
  • 258
  • 1.57K
Message 7 of 8
@MikeRobbo wrote:
........ tour Upstream Power Levels however are are all too low at 16 QAM, they should be at 64 QAM........
Clearly a “DUM” diagnosis as the actual Upstream (CM)power levels appear to be within spec? However Dynamic Upstream Modulation on shared cable segment is susceptible to noise from various local and upstream sources....
Regards Tony
"Life is a Binary Inspired Turing Computed Hologram"(don't PM or @Mention me - in case ignoring you offends)
DEFROCKED
  • 6.93K
  • 359
  • 613
Message 8 of 8
Hi Five
Thanks for posting and welcome to the community. My apologies for the delayed reply and the broadband issues.
I've checked the system today and can see no issues with the services. I hope everything is sorted, however, please let us know if you need further assistance.
Kind regards,
John_GS
