Hi everyone
I have just had the 100 Mbps service installed.
I've hooked it up to my tenda mw3 mesh and while the signal is much more consistent around my house, the speed is pretty slow. I'm getting between 30 and 70mbps.
I have tried various combinations of setting the hub to modem mode and the tendas to DHCP. I've also kept the hub 3 in router mode, turned the WiFi off and set the tenda to bridge mode.
I'm not sure what else to do. When I connect to the hub directly I'm getting speeds of over 100 Mbps. The WiFi at the moment seems slower than my Plusnet which I also set up with the tendas.
Would buying a single mw6 and setting that up as a primary node solve the problem?
