Message 1 of 8
TP-Link RE300 AC1200 Mesh Wi-Fi
Hi all,
We've just joined Virgin Media so have the latest superhub but it doesn't quite reach the kitchen.
I was looking at getting the TP-Link RE300 AC1200 mesh range extender. Is the superhub compatible with this and would it work well?
Jamie
  • 15.69K
  • 1.64K
  • 2.68K
Message 2 of 8
Re: TP-Link RE300 AC1200 Mesh Wi-Fi
Yes and No.
You can do a lot better for a bit more money
  • 2.29K
  • 168
  • 303
Superfast
Message 3 of 8
Yeah it should work fine.
It appears it can use WPS (Wi-Fi Protected Setup) so in theory all you have to do is plug it in, press the WPS button on the HUB 3, then the button on the TP-Link, and it should be ready to go as an extender, using your existing SSID (Network Name)!
Message 4 of 8
So i won’t need to connect onto the extender it’ll just use the existing WiFi network name as if it’s the exact same signal?
Will it slow down my internet speed?
  • 2.29K
  • 168
  • 303
Superfast
Message 5 of 8
Yes, it looks like it reading the details of the item. Using it as extender means just that, it extends your existing network.
You can never guarantee Wifi speed, so I can't confirm that your internet won't be slower, you get what you pay for as they say!
Buy it from somewhere like Amazon that has a decent returns policy.
  • 20.96K
  • 1.14K
  • 2.7K
Message 6 of 8
It won’t really boost it.
And if the signal is poor you may inevitably end up just extending a poor signal even further.
Message 7 of 8
Ended up going for the TP Link TL-WPA4200 AV600.
it works brilliantly.
it comes with a clone function that allows it to clone the existing WiFi’s name and login details so you don’t have to keep switching to different access points.
would recommend!
  • 2.29K
  • 168
  • 303
Superfast
Message 8 of 8
Glad you sorted your issue.
