on 06-02-2023 20:08
Hi There,
I'm looking for some support, as this takes way too long.
I had my router replaced twice, every engineer was tweaking power levels back and forth saying that they a right. All connectors and filters replaced. Recently (December 21st) I had new cable ran to my house and today cabling inside replaced.
The long story short, problem is still here, and nobody know what to do...
I have started logging the router data and some screenshots of the upload and download tabs.
Download link https://we.tl/t-tqOMQmYmMq |
1 item |
T3-T4_log.xlsx 3.15 MB |
on 15-02-2023 19:08
In most of those snapshots the upstream power level if far too high. This is usually a loose connection, bad cable of street box problem. Unless there is an area problem you will need a technician’s visit to rectify.
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
VM will not dispatch any technicians while an area fault exists.
If no area faults found:
The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
on 15-02-2023 19:41
Hi Tudor,
Thank you for tat.
I know that the signal levels are to high, however past 2 years every technician visit was adjusting that by fiddling in the street box or adding or removing filters and 3 router replacements.
Signal too high, signal too low, signal too high, signal too low... I've replaced connector here, and I replaced connector there...
Finally December 21st I had new cable ran to my property, but this made no change.
I keep hearing over and over the same explanations. I'm not saying that those are wrong, but maybe they are looking in the wrong place.
I don't know why signal fluctuates from 38 to 58, where majority of time is stable 38.
Please HELP !!!
on 16-02-2023 19:34
Another quick question is my SNR ok???
1 | 587000000 | 3.9 | 40 | QAM 256 | 23 |
2 | 411000000 | 1.9 | 40 | QAM 256 | 1 |
3 | 419000000 | 1.8 | 40 | QAM 256 | 2 |
4 | 427000000 | 1.8 | 40 | QAM 256 | 3 |
5 | 435000000 | 1.8 | 40 | QAM 256 | 4 |
6 | 443000000 | 1.8 | 40 | QAM 256 | 5 |
7 | 451000000 | 2 | 40 | QAM 256 | 6 |
8 | 459000000 | 2 | 40 | QAM 256 | 7 |
9 | 467000000 | 2.3 | 40 | QAM 256 | 8 |
10 | 475000000 | 2.6 | 40 | QAM 256 | 9 |
11 | 483000000 | 2.7 | 40 | QAM 256 | 10 |
12 | 491000000 | 2.8 | 40 | QAM 256 | 11 |
13 | 499000000 | 2.7 | 40 | QAM 256 | 12 |
14 | 507000000 | 2.6 | 40 | QAM 256 | 13 |
15 | 515000000 | 2.7 | 40 | QAM 256 | 14 |
16 | 523000000 | 2.6 | 40 | QAM 256 | 15 |
17 | 531000000 | 3.2 | 40 | QAM 256 | 16 |
18 | 539000000 | 3.6 | 40 | QAM 256 | 17 |
19 | 547000000 | 3.7 | 40 | QAM 256 | 18 |
20 | 555000000 | 3.8 | 40 | QAM 256 | 19 |
21 | 563000000 | 3.7 | 40 | QAM 256 | 20 |
22 | 571000000 | 3.8 | 40 | QAM 256 | 21 |
23 | 579000000 | 3.9 | 40 | QAM 256 | 22 |
24 | 595000000 | 4 | 40 | QAM 256 | 24 |
25 | 603000000 | 4 | 40 | QAM 256 | 25 |
26 | 611000000 | 4.3 | 40 | QAM 256 | 26 |
27 | 619000000 | 4.4 | 40 | QAM 256 | 27 |
28 | 627000000 | 4.4 | 40 | QAM 256 | 28 |
29 | 635000000 | 4.5 | 40 | QAM 256 | 29 |
30 | 643000000 | 4.6 | 40 | QAM 256 | 30 |
31 | 651000000 | 4.4 | 40 | QAM 256 | 31 |
1 | Locked | 40 | 43795 | 2627 |
2 | Locked | 40 | 5107 | 1855 |
3 | Locked | 40 | 38537 | 2805 |
4 | Locked | 40 | 4350 | 1662 |
5 | Locked | 40 | 49901 | 2842 |
6 | Locked | 40 | 57747 | 3415 |
7 | Locked | 40 | 58138 | 2634 |
8 | Locked | 40 | 76036 | 3322 |
9 | Locked | 40 | 20690 | 2270 |
10 | Locked | 40 | 60184 | 3423 |
11 | Locked | 40 | 49833 | 2709 |
12 | Locked | 40 | 45994 | 2563 |
13 | Locked | 40 | 51354 | 1865 |
14 | Locked | 40 | 1364 | 663 |
15 | Locked | 40 | 1364 | 735 |
16 | Locked | 40 | 692 | 410 |
17 | Locked | 40 | 487 | 344 |
18 | Locked | 40 | 1007 | 665 |
19 | Locked | 40 | 450 | 422 |
20 | Locked | 40 | 379 | 331 |
21 | Locked | 40 | 838 | 632 |
22 | Locked | 40 | 407 | 434 |
23 | Locked | 40 | 780 | 653 |
24 | Locked | 40 | 1617 | 756 |
25 | Locked | 40 | 799 | 490 |
26 | Locked | 40 | 399 | 374 |
27 | Locked | 40 | 363 | 422 |
28 | Locked | 40 | 1117 | 701 |
29 | Locked | 40 | 236 | 320 |
30 | Locked | 40 | 191 | 329 |
31 | Locked | 40 | 188 | 307 |
on 16-02-2023 19:37
on 16-02-2023 20:18
OK, I have found a way of sharing the spreadsheet without being accused of spreading malware.
Please find all the data I've gathered so far in the google doc link below:
https://docs.google.com/spreadsheets/d/1fL7N6haxP6i4GicfM5BiCe6Mqun6oh6a3R2EH4UBoB4/edit?usp=sharing
Please also keep in mind that all data is collected after the new cable being ran from the "junction box" to my property, and all in-house wiring and connectors replaced.
on 18-02-2023 17:05
New link, as requested
checked and confirmed by friends of mine... Link is working as intended.
on 18-02-2023 17:18
Significant numbers of Downstream Pre RS and worse Post RS errors across all of the DOCSIS 3.0 channels.
on 18-02-2023 17:20
Ok, great, thank you for that.
Any idea what can cause this?
on 18-02-2023 17:39
That diagnosis doesn't take into account the cumulative nature of the post-RS errors.
For the benefit of the OP, when there is noise on the line, data is likely to be corrupted. Much of the time, using something known as "Reed-Solomon Error Correction" (hence "RS), corrupted data is corrected. The amount of corrupted data is recorded as the "Pre-RS" number; the "Post-RS" number is the number of uncorrectable data symbols. When a Hub is rebooted, it is not in a state of grace for a few moments and everything on that segment, whether for the particular hub or not, hits that hub and is unintelligible. Post-RS errors are thus racked up in those moments. Then there are Post-RS errors that arise because the SNR on the downstream falls to 34dB or below; noise is greater than signal.
Your snapshot shows 40dB SNR. If it always does that, and the Post-RS errors aren't rising, then the numbers are legacy and can be ignored.
on 18-02-2023 18:01
Hi Sephiroth,
Thank you for that, this is greatly appreciated.
Can you please take a look at the link I've included?
It contains data from 21st December and can give you better insight.
I do swear on my life this is not any malicious stuff. Please check on some mobile device first if you have any concerns.
This is simple google doc excel spreadsheet.
I'm only desperate for a solution, as nobody knows what the issue is and it s over 2 years already.
I would change a provider, but there is no one near the VM speed in Warwickshire for now...
Well Fiber city will be here soon (TM), but who knows when.
