Matt8787
  • 16
Message 1 of 10
Switching over from Hub 3 to 4
I’ve just had a new install completed and the engineer installed a virgin Hub 3.0.  I happen to have a Hub 4.0 still from a previous contract so was looking to swap them over to use the 4.0 - but with the 4.0 hooked up, I’m just getting a red light on the Hub - any ideas?
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Message 2 of 10
Re: Switching over from Hub 3 to 4
@Matt8787 wrote:
you would need to call VM and ask them to activate it - they may refuse though.
did they not ask for it at the end of your previous contract?
apcyberax
  • 33.44K
  • 1.87K
  • 5.94K
Message 3 of 10
if its from an old contract it will not be on your account and normally policy is not to add them.
You should of returned it or VM would charge you. How long ago did you end the contract? they may still want the Hub4 back
Matt8787
  • 16
Message 4 of 10
Thanks - think I’ll just switch it back to the Hub 3 then
Old contract only ended on Friday
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Message 5 of 10
They will be expecting the hub4 back then.
Matt8787
  • 16
Message 6 of 10
Begs the question as to why I was given a Hub 4 last time, Hub 3 this time
apcyberax
  • 33.44K
  • 1.87K
  • 5.94K
Message 7 of 10
what service did you have before and what do you have now.
The hub4 is only for gig1 packages.
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Message 8 of 10
Though sometimes offered to people in docsis 3.1 enabled areas but not on gig...
Matt8787
  • 16
Message 9 of 10
Well before I was on a 200mb package and now I’m on the 500mb package
Ernie_C
  • 18.14K
  • 1.97K
  • 4.39K
Message 10 of 10
They probably rewarded you for cancelling and signing up as a new customer.
