on 01-04-2023 17:10
Hi all,
I am on the M125 speed broadband, and I work from home regularly. We use Microsoft Teams for work calls and I’ve noticed that when on calls it frequently hangs, sometimes the video then kind of fast forwards as it catches back up, but more often it just drops the call altogether.
I have run the basic diagnostics on the line to try and determine if I have faults, the only one I am seeing from the router logs is detailed below.
I run the Hub 3.0 in modem mode.
Here are the Hub details:
Standard specification compliant | : DOCSIS 3.0 |
Hardware version | : 10 |
Software version | : 9.1.2109.200 |
The faults I’m seeing in the logs are as follows:
21:42:32 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
31/03/2023 21:42:32 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
31/03/2023 21:42:32 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
31/03/2023 21:42:31 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
I have checked all cables/connections and everything appears to be secure.
Please can you advise next steps in helping me to resolve this issue?
many thanks,
Alastair.
on 01-04-2023 17:18
on 04-04-2023 10:59
Good Morning @Alihawk78, thanks for your post on our Community Forums, and a very warm welcome to you!
Sorry to hear of the recent issues you've been experiencing with the connection to our broadband services.
If you're able to confirm the answers to the questions posted by @jbrennand, that would be a great starting point for us to work with.
Kindest regards,
David_Bn
