Lovebug99
Message 1 of 20
Sure Signal on Vodafone
Hello All
My sure signal stopped working about 7 days ago.
I have called Vodafone who said it was a network timing protocol and to speak to my ISP.
I have checked all the settings on the router and done a test which seems to be OK.
I have spoken to Virgin media after waiting for about 3 hours an they said they would reset my WIFI and boost my service.  They said this should fix it although I was not confident the engineer knew what he was talking about.
This has still not worked.
There a lot of other posts on this board with the same problem.
I do not get any service at home for my mobile unless I use Sure Signal.
Come on Virgin Media can we have a solution please
Thank you
jb66
  • 12.28K
  • 912
  • 1.79K
Message 2 of 20
Re: Sure Signal on Vodafone
Doesn't your mobile do WiFi calling which would mean you don't need the suresignal box?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 20
With such a flurry of posts about the Vodafone Sure Signal I reckon there is a discrepancy between the VM time and the Vodafone time, and with it only seemingly affecting Vodafone I reckon the problem is with their Network Time Protocol (NTP) Server.
Smudger1
Message 4 of 20
SORT IT OUT VIRGIN 2 weeks with no signal
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 5 of 20
WHY ARE YOU SHOUTING?
How do you not know this isn’t Vodafone’s issue?
jb66
  • 12.28K
  • 912
  • 1.79K
Message 6 of 20
Did you even TRY to enable WiFi calling in your phone?
Eeeps
  • 822
  • 53
  • 136
Well-informed
Message 7 of 20
WiFi calling is the way forward (especially when Vodafone switch off Sure Signal).
Even some of the MVNOs support it now (Virgin Mobile being one of them).
Curti007
Message 8 of 20
Wifi calling is an awful alternative, I have no bars but one outside my house which means our mobiles get a wiff of a signal so wifi calling doesn't work and calling and texting don't get through, I have read on here that most people are experiencing similar that's why they have a sure signal.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 20
Does that little VF box in your house give you a decent signal outside or is it just an indoors thing ?
jb66
  • 12.28K
  • 912
  • 1.79K
Message 10 of 20
My wife gets texts and calls no problem through wifi calling on vodafone, i'd suggest you do some troubleshooting with vodafone
