  • 12
Message 1 of 16
Superhub3 issues for many if pfSense firewalls used
Hello,
These seems to be a common issue in the UK with many users with regards to using pfSense with Virgin Broadband. They use something called a Superhome Hub 3 that you can put into modem mode and cable into your pfSense device or virtual host.
https://www.reddit.com/r/PFSENSE/comments/gh6gdl/gateway_alarm_wan_dhcp_with_virgin_hub_router/
Some say it's to do with the Puma chipset the Virgin Superhub3 uses, but it's causing many issues for lots of people including me. It doesn't matter if you are virtual or physical either.
We have tried changing the thresholds and disabling GW monitoring, but still get the issue. It seems to happen more during video calls we have all found (Zoom/Teams).
If you restart the router & pfSense we have found it to work better for a day or 2.
Upgrading from 2.4.4 to 2.4.5 doesn't make any difference.
Some have started to use other FWs and they are better.
Any ideas would be great or any extra logging I can do and post.
  • 3.96K
  • 715
  • 1.03K
Message 2 of 16
Re: Superhub3 issues for many if pfSense firewalls used
Hello
I have the hub 3 with the following details -
Hardware version: 10
Software version: 9.1.1811.401
Also running the latest pFSense running on a i5 2400s -
2.4.5-RELEASE (amd64)
built on Tue Mar 24 15:25:50 EDT 2020
FreeBSD 11.3-STABLE
What is the actual problem you are having ? as I have mine running pretty much 24/7, with pfsense / hub 3.0 reboots approx every 2 weeks and have no problems at all.
Regards Mike
  • 13.98K
  • 576
  • 1.33K
Message 4 of 16
setup a BQM
  • 95
  • 14
Dialled in
Message 5 of 16
What use is BQM if no one from Virgin does anything with that info? The amount of high latency BQM posts in the last 2 weeks should be enough already.
  • 291
  • 8
  • 36
Superfast
Message 6 of 16
I have been using pfSense / Hub 3 for many years and it works great
amd 5350 APU 2.4.5 release. Currently 44 days since last boot.
getting 500 Mb without issue
Alpha SSL, HA proxy
openvpn road warrior, HE IPv6, Nord VPN tunnels.
All work as intended.
  • 12
Message 7 of 16
I thought mine was fine until there was the lock down in the UK and we all had to work from home, it's mainly triggered on large conference calls like Zoom.
A restart of the SH3 always fixes things for a few days.
Is your pfSense box physical or a VM?
  • 51
  • 10
Message 8 of 16
20th April (well into lockdown) was when it all started going wrong for me.
https://community.virginmedia.com/t5/Networking-and-WiFi/Intermittent-packet-loss-high-latency-throu...
Firmware update, then it got progressively worse over 2-3 days.
Can those with BQM check their results from 19th-24th April for each day and see if there's a worsening trend?
My Broadband Ping - Home
  • 6
Message 9 of 16
I have been having these issues. I have just updated to pfsense 2.5.x development version which upgrades the version of the underlying OS (BSD 11 > BSD 12) and this seems to have solved my issue.
I believe there is a bug with the latest VM modem firmware when you are in modem mode.
Only upgraded a couple hours ago and connection is 100x times better. See the below BQM.
BQM Ping Graph
  • 12
Message 10 of 16
This is interesting! Let's see how you get on.
I always find after the SH3 or pfSense is rebooted it's always better for a day or so.
How did you upgrade to 2.5.x Dev?
