on 03-10-2020 17:17
Hello,
Wonder if someone can help with a frustrating problem. For longer than I can remember, I have been using a Superhub 2 in modem mode, together with an Asus RT-AC66U router.
The reason why I set it up this way was because I found a particular online game would frequently disconnect and give lag spikes. I found that by putting the Superhub 2 in modem mode and using a separate router, the disconnects and lag spikes went away. I happily used the system in this configuration for years.
I recently upgraded my package to 1 Gig and was sent a Superhub 4 router. I was optimistic that whatever problems caused the lags and disconnects with the Superhub 2 would now have been fixed. My optimism was misplaced. As soon as I started using a Virgin router again, the lags and disconnects started up again!
No problem, I thought, I'll just put the Superhub 4 in modem mode, and use my own router, just as I had been doing without issue for several years. That was the start of an almost entirely wasted day. It seems the Superhub 4 simply does not work properly in modem-only mode.
I get the following error message within my Asus router's configuration page. "Unable to connect to the Internet". Please contact your ISP to find out the root cause of the DHCP failure.
I googled and found many people seem to be having the same problem with the Superhub 4 in modem mode. It seems some people tried various things like swapping ethernet cables, trying different ethernet ports, rebooting the Superhub, leaving it for 5 minutes, then turning on the router, leaving it for another 5 minutes. I tried all of that, and more, for several hours. I just get that DHCP failure error and no internet connection.
So I have reverted back to the Superhub in router mode, using the Asus device for wifi. (I have tried two separate routers, one brand new, and get almost identical error messages: ISP DHCP failure).
This is absolutely not how I wanted my service to work. I want my own router to do all the routing, and the Superhub 4 to be a modem and nothing more.
Any ideas? Note that the basic trouble shooting tips like trying a new ethernet cable, trying a different ethernet socket, rebooting all devices in a different order etc etc are unlikely to work. (Tried them all, no joy).
Many thanks in advance
Answered! Go to Answer
on 03-10-2020 17:22
on 03-10-2020 17:22
03-10-2020 17:47 - edited 03-10-2020 17:48
Thank you, I did something a bit like that but will try that exact sequence. Note that my SuperHub is a 4 so it does not have any magenta light. It has only one light, a white strip. Here’s a pic. Does that make any difference?
It seems to be the 4 that is giving everyone problems in modem mode.
on 03-10-2020 20:02
on 03-10-2020 23:33
on 04-10-2020 11:13
John,
I was sceptical at first as I tried what I thought was every sequence under the sun over a period of about 6 hours yesterday. Nothing worked.
But I then followed the exact sequence used in your message and it worked immediately. Thank you VERY much.
Look at this speed I'm now getting over wifi (ax). https://www.speedtest.net/my-result/d/7a8f59bc-50ce-4337-8476-5f2c28103d89
Sadly, the manual says nothing about how to set up modem only mode on the Superhub 4. It was never this difficult with the Superhub 2.
on 11-12-2020 03:54
Did you get it to be stable tho?
I have an Asus Rapture connected to SuperHub4 in Modem Mode and it needs restarting every few days.
It will literally just drop connection, I wont be able to see it on 192.168.100.1 until I restart it.
on 27-10-2021 19:17
well i have a hub 4, tried everything to stop wifi drop out. i have a solution which is working as i write. i have 1gig tested to the hub 4, tried modem mode but doesnt work. returned hub4 to router mode. plugged a cat5 into talktalk modem/router wlan port. i now have stable wifi through talk talk modem/router. also connected cat 5 to an old sky modem and shared the ethernet port. am trying to post images of setup not sure how
on 27-10-2021 23:59
@Eddie701 wrote:well i have a hub 4, tried everything to stop wifi drop out. i have a solution which is working as i write. i have 1gig tested to the hub 4, tried modem mode but doesnt work. returned hub4 to router mode. plugged a cat5 into talktalk modem/router wlan port. i now have stable wifi through talk talk modem/router. also connected cat 5 to an old sky modem and shared the ethernet port. am trying to post images of setup not sure how
Just another way not done properly.....😑
on 25-11-2021 21:56
I have got a RT-AX88U router today. I put my hub4 into modem mode but I just can't get any internet. As for the white light it's either on or off dosent mean it's in modem mode or router mode. It's the same for both. Been trying all day and getting nowhere.
